Old 03-16-2019, 11:56 AM   #1
Condensation on windows!
Advice needed! We’re staying in our travel trailer on a lake where it is cool outside. We’re running our heat and had our bathroom vent open as always. We woke up this morning to condensation on all of our windows. We have Dri-rid we keep in our camper. What caused the condensation and how can we stop it and clean the windows??? Any suggestions or advice is greatly appreciated!!! Thanks in advance!!!
plh869 is offline   Reply With Quote
Old 03-16-2019, 12:28 PM   #2
You likely caused the condensation on the windows.
Your breathing, as well as your cooking and bathing.
Condensation happens in houses quite often where it stays cold for some time in the winter.
Cold windows cause humidity to condense on the glass, it will run down and cause the wood in the sash to rot after a while.
The solution; double paned windows. The inside pane is insulated from the outside glass by a layer of air sealed between them.
You don't have that luxury in an RV.
Either keep the humidity lower inside, by opening the vents, breathing/cooking/living less, or run the heat warmer (cars do this by blowing warm air on the windows) to warm up the windows above the dew point.
Or buy some sealing wrap for the windows (3M Window Insulator Kit, $20 or so on Amazon).
I would do the last thing. It works well, saves heating costs, is easy to apply, and most importantly; easy to remove.
It is essentially plastic wrap that covers the windows. I use it on the older single pane windows in my house.
sirtate is offline   Reply With Quote
Old 03-16-2019, 12:35 PM   #3
moisture is always going to go to the coolest spot in the room. aka as your single pane rv windows. Burning propane also causes moisture along with breathing and cooking like already stated. Run a dehumidifier in your shower if it bugs you and keep your bath vent open
Kimber45 is offline   Reply With Quote
Old 03-16-2019, 01:07 PM   #4
Flybob's Avatar
If you are having condensation on the windows, you will likely have condensation under the mattress if it is over an unheated area. The moisture from your body penetrated the mattress and condenses on the cold bed deck surface. If you have this issue, you can place a 4' X 8' sheet of 1/2" construction foam under the mattress.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-16-2019, 01:14 PM   #5
One of the simplest ways is to get some air moving. Run a fan that will circulate the air. As others have posted, your breathing, running water, cooking, showering, etc. will cause humidity. Dry that humidity up with heat and moving air.
Yes, a dehumidifier would work great, but the difference in cost - $15 for a fan and $150+ for a dehumidifier. Try the fan first. If it works, great. If not, buy the dehumidifier and you can still use the fan for other things.
merrykalia is offline   Reply With Quote
Old 03-16-2019, 02:30 PM   #6
Another huge difference between fan and de-humidifier. A fan merely keeps air moving so you don't see the condensation on the windows. It still forms in the cool corners and in cabinets where the fan isn't circulating air.
A Dehumidifier will actually REMOVE the moisture that is given off by humans and their activities. An RV is far more confined than a house where there are greater exchanges of air with the outside.
There is one fan that will help but only if used reguarly and that's the exhaust fan over the stove (which should be on whenever the stove is lit) and the bathroom fan which is a must when showering. Most people don't use the fan over the stove because it's too noisy but unless they do, just be prepared for condensation. Then hope warm weather shows up so you can open up and let the accumulated moisture permeating everything escape.
#1 reason why manufacturers say "This unit is not meant for permanent occupancy".
I have it on my dog's authority that an afternoon nap is acceptable.
Politically Incorrect since 1943
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old Today, 08:15 PM   #7
CincyGus's Avatar
Buy Electric Blanket for the bed and top it off with a quilt, leave the bath fan running along with one of the bedroom windows cracked an inch or so. And set your thermostat about +20 or 25 degrees above the outside temp.
Drawing in dry cold air from the outside helps absorb some of the moisture you are giving off in the bedroom and is exhausted through the bathroom.
It basically comes down to reduce the temp difference between inside and outside
AND
Increase the movement of moist air out of the camper, preferably while introducing drier cooler air.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
window
