Old 08-10-2008, 09:09 AM   #1
considering a fifth wheel
Im thinking about purchasing a new classic lite fifth wheel. I have a standard Ford f150 1/2 ton. Flagstaff 8528GTSS fifth wheel. dry weight weight 6200. hitch weight 1081. I plan on adding air bags to the springs.
no mountain pulling. F150 suggested gwr is 6500. would this possibly be to much to consider?
dlmarris is offline   Reply With Quote
Old 08-10-2008, 01:54 PM   #2
pin weight may be more than listed
We have a rockwood 8281 and tow with f250 4x4 5.4l. The trailer is a 2008 and we will be getting something a bit more powerfull as soon as possible. If you have 4.10 rear you should be ok but will know its behind you. We havn't been to the scale yet but im sure pin weight has got to be more than forest river has listed. Good luck.
familyman is offline   Reply With Quote
Old 08-14-2008, 05:14 AM   #3
amxpress's Avatar
dlmaris,
I've seen it done before with an F-150, but you are probably pushing the weight limits. Air bags don't increase your truck's GVWR or combined weight rating, it just keeps the back of the truck from dropping down because of the load.
Check ALL the numbers and how your truck is set up.
Good luck with your setup. Be safe.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 08-14-2008, 02:25 PM   #4
froglegs's Avatar
If yours is a 4x2 you should be ok. I have a 4x4 and the gwr is 400# less. We have pulled ours for 2 years and no problems yet.
2000 F-150 4x4 sc,off road pkg,Tow Pkg,5.4,3.73TL,2007 Flagstaff 8524RLS,and One Happy Maltese! See You Down The Road!!!
froglegs is offline   Reply With Quote
Old 08-14-2008, 04:40 PM   #5
If the dry weight is already within 300 lbs of your max towing weight then you will be well over the limits after you load the trailor with all the essentials. Whatever you load into the trailor, has to be added to the dry weight and believe me it adds up quick. Chairs, food, water, drinks, propane clothes, etc....
Also the listed towing capacity of the truck does not take into account your on body weight and gas.
John & Wendy
son Tyler and little miss priss Maggie (beagle/terrier)
2006 F-250SD CC
2004 Cherokee Lite 275L 5er
johnthen is offline   Reply With Quote
5th wheel
