Old 12-26-2015, 05:45 PM   #51
Dream truck
Originally Posted by Cover Dog View Post
In a perfect world my truck would have a Dodge Cummins engine, Chevy Allison transmission, and a Ford's suspension.
That trailer doesn't have much in the way of CCC I'm sure you will use that up in no time.
Good luck with you search .
Yes my dream truck to
tonyb1725 is offline   Reply With Quote
Old 12-26-2015, 06:49 PM   #52
mike.t's Avatar
My Ram 2500 is a basic truck(not the cheapest) no foo foo stuff/ cloth=warm in winter cool in summer 820 ft lbs 12 to 14 pulling a 9k TT a absolute beast. Ya can't go wrong And 4X4 new just under 46k and I got 30k for my 11'2500HD Silverado.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 12-26-2015, 07:32 PM   #53
ryand's Avatar
Others have said.....and your photos indicate a RV of roughly 8K loaded to capacity. 3/4 ton would be my recommendation. Make not really important nor is the power plant IMO at that weight. You mentioned future plans...that may push you to a oil burner. For me anything under 10K trailer weight....power plant irrelevant as they all are up to the task....however the class of truck is the major issue. good luck.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 12-26-2015, 07:51 PM   #54
The 6.7 Cummins and 6.7 Ford both have strong points. I can tell you from experience that the Ford is a stronger running engine than the Cummins. The Cummins is more than up to the task with 2 less cylinders. The Ford is a V8 and the Cummins is an inline 6. I also believe that the Ford "truck" is better built than the Dodge. The Ford 6 speed auto is a great transmission, and I believe it is built tougher than the Dodge. The Aisan transmission is supposed to be great also.
That's my 2 c. As to 3/4 vs 1 ton. No question there in my mind....buy the 1 ton. Very little difference in cost and you gain an overload spring, spacer, and (I believe) front coil spring is heavier duty.
Good luck
dg
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 12-26-2015, 09:49 PM   #55
mike.t's Avatar
As i said before "you will upgrade" and if you can. Go diesel. Far better resale. Last forever and will kick a gasser's ass when talking MPG while towing a good size comfortable TT/5er. Ford has been trying to replace that great 7.3 they had and i have read the new 6.7 is very good. However google "Cummins" stay with what works. Again IMHO.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 12-31-2015, 07:26 PM   #56
RangeMaggotBob's Avatar
Originally Posted by oldtool2 View Post
I forgot to post the photos so I will post them this time.
It seems I may have given the wrong impression here. I believe the truck I have is capable of knowing what I want but I won't know for sure till I pulled up the mountains. If I'm not satisfied with it then I'm going to go looking for a new truck. A friend of mine is trying to talk me into a diesel and I've never owned one before.
Naturally if I go for a new truck going to get something bigger and capable of hauling something heavier than what I have now. My question is who makes the best diesel and why do you think that. So far it looks like a Cummings but I'm really not getting the information I'm looking for.
Who makes the best diesel and why do you think that? A fairly straightforward question.
Jim
Better start looking now, cause what you got just ain't gonna make it in the mountains. And here's a fairly straightforward answer- Cummins. Reasons being- among many others- you can see underneath the hood. If serviced correctly through the years, there's no reason you shouldn't be good for 750K plus. Just a few reasons among the many as to why the Cummins is the way to go. I looked at the Ford and the Chevy, both are very nice- but- jump into the RAM, and you'll see what I mean... My wife and I go "Whew!" everytime we see those commercials about which truck is the truck of the year. We came close, but eventually made the right decision.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
Old 12-31-2015, 07:49 PM   #57
Kenny kustom's Avatar
Good luck
dg
Before the aisin, I would rather the ford tranny.
Now, with the aisin.. Worlds different from the old dodge trans.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 12-31-2015, 08:17 PM   #58
Kenny, I'm hearing good things about the Aisin Transmission, but the Dodge frame/body scares me. A close friend of mine bought a 2012 Dodge with the 6.7. Man that engine pulls like a freight train, and even so, my Ford will both out pull and out run it. Which engine will last longer? I don't know, probably both will last longer than me with decent maintenance, but as much as I like my 6.7 Ford, I would bet my money on the Cummins running the longer miles, all things being equal. Right now, my friend is waiting to have the spring bushings replaced in his truck. Local Dodge dealer diagnosed "that knocking" sound over a month ago, and still waiting on parts. 2012 year model with 34k miles. That bugs me. Now, is it an anomaly? Maybe, but as for me and my dollars?....I gotta go Ford. I just wish that Toyota had a 3/4 ton with a proven diesel.
Having said all that, it's just my opinion.....my opinion and a dollar bill might get you a cup of coffee at McD's. ��
Old 12-31-2015, 08:26 PM   #59
mike.t's Avatar
A spring bushing went bad and that was the reason you stayed with your ford?
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 12-31-2015, 08:46 PM   #60
Mike, don't get your panties in a knot now. It's not that big a deal. I only listed one example. If you want several more, shoot me a pm. Better yet, I'll put you in touch with my buddy. His 2500 has a "For Sale" sign on it. Ya'll could compare notes, but he has a contract on a new Ford. As for me? i stayed with what works for me. I suggest you do the same. Such a simple concept isn't it? Happy New Year!
truck
