Old 02-12-2015, 11:30 AM   #1
Dealer prep items (weight)
I'm new here so sorry if this has been covered exhaustively.
What items are added on at the dealership vs. at the factory? I'm curious WRT weight being added after the unit leaves the factory. Batteries, propane tanks, awnings, slide toppers?
2015 Micro Lite 25KS
2006 Suburban 2500 8.1 L
220Chap is offline   Reply With Quote
Old 02-12-2015, 11:44 AM   #2
You can go to a manufacturers website and see the standard equipment and the base or dry weight of a vehicle. This weight will reflect all of the items that come standard from the factory. Any upgrades will affect the weight. Going to 30 lb bottles from standard 20lb. Batteries do not come standard so that will be added weight. Other added weights include, toppers, covers, equipment, cargo, water, PEOPLE.
Basically anything that you add on or upgrade that did not come as standard equipment will not be depicted in the weight from the factory.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 02-12-2015, 11:44 AM   #3
TURBS's Avatar
Depends on how you ordered it.
At the bare minimum full propane tanks and a battery.
Old 02-12-2015, 12:12 PM   #4
I didn't order my trailer, so I don't know what it shipped from the factory with, which is why I asked.
Thought perhaps it was common for some items to be added at the dealership after shipping.
Kinda figured the dealership wasn't gonna add "cargo, water, or people".
Old 02-12-2015, 12:15 PM   #5
TURBS's Avatar
"Normally" awnings are shipped with unit unless dealer orders it without cause they have one cheaper in stock.
Factory has just started adding slide toppers from the factory if there ordered that way.
Old 02-12-2015, 12:24 PM   #6
In that case then probably you just need to account for batteries and the weight of propane in the tanks. Typically a dealer will add nothing to a unit unless a buyer wants some mods upgrades done before taking delivery.
Not sure if it is the unit in the sig but you could ask the dealer where you bought it or if you bought it privately email the manufacturer with your VIN and they will give you a build sheet, compare the sheet to the installed equipment to see if anything has been added or upgraded.
Just some thoughts depending how important it is to you. I went the VIN route to see if my "arctic package" was included in the yellow sticker weight.
Old 02-12-2015, 12:42 PM   #7
Canadian Member
itat's Avatar
Most of the units I've looked have a yellow sticker that's well over the brochure weight and the yellow sticker doesn't account for the battery and propane. I suggest that maybe the brochure weight doesn't even include the "standard options".
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 02-12-2015, 12:48 PM   #8
TURBS's Avatar
Brochure weight and sticker weight were within 200 lbs on my unit.
Old 02-12-2015, 12:59 PM   #9
I thought the same thing and I contacted FR about it because I was confused. FR told me that the brochure weight was the unit with only standard features, which equates to the bare bones unit. The brochure weight does not include thins like a gas and electric water heater, the brochure would correlate to just a gas water heater since that is the standard equipment, the brochure weight is a regular awning not a powered one and another one was the brochure weight does not reflect black tank flush since it is not standard equipment. He reiterated that if you made the unit the simplest and cheapest including AC options that is the brochure weight.
All of this info I was told was about an EVO 2850 so I am not sure if each brand is the same.
For my unit the yellow sticker was the exact weight of my unit (within 100 pounds due to a dual bat setup and I put 30lb tanks and took the 20s off).
I weighed my truck on the way to pick it up and then weighed it again while driving back home. The difference was pretty close to the yellow sticker, it was off a tad due to about a gl of antifreeze, batteries, hitch and 30 lb tanks.
On the lot I compared a 2850 artic to a 2850 non arctic and the yellow stickers were about a 50 pound difference. The only thing different about the unit was solely the Artic package. So for the newer units I believe the yellow sticker is pretty close to what it is when it leaves the factory.
Because of this I go off the yellow sticker because it seems way more accurate than trying to see brochure to real life.
Old 02-12-2015, 06:13 PM   #10
Thanks guys. A build sheet would be good to have.
Related: A/C seems to be standard (maybe not?), yet the specs list the height of the unit w/o the A/C unit. Ain't this fun?
dealer, weight
