Old 08-29-2018, 09:26 PM   #1
Did you install correct track to raise your 5er?
I need to raise my trailer to fit my stock Ram 3500 DRW 4x4.
Looking to see how many of you have done it and how did your install go.
https://www.lci1.com/support-correct-track%E2%84%A2
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 09-19-2018, 07:37 PM   #2
Casey & Carolyn
Casey r's Avatar
Havenít done it yet but real close to doing that mod. Probably within the next month. Will be replacing bushings with never fail and pins with wet pins.
Casey and Carolyn Rice
Las Vegas Nv
2017 Prime Time Crusader Lite 29 RS
2018 Ram 3500 4x4 CC Cummins Powered
Casey r is offline   Reply With Quote
Old 09-19-2018, 09:23 PM   #3
Curious why you would pair wet bolts(more maintenance) with never fail bushings(no maintenance). Do never fail bushings recommend using wet bolts?
I am asking as I put wet bolts on previous rig only to be warned on this forum to be timely on maintenance as the brass sleeves wear quickly if not maintained. I was shocked at the maintenance interval of those wet bolts.
Regardless, keep us posted on the mod.
Old 09-20-2018, 07:10 AM   #4
Justice12t's Avatar
I was looking at something like this myself. New F250 still sits too high even will both hitches adjusted. The little squat I get helps but I'd rather have some extra play room for adjustment. I'll keep an eye on this thread...
2016 Prime Time Crusader 294RLT
2018 RAM 2500 Laramie CTD, CC, 4x4...ect
2017 Days Camped - 14
2018 Days Camped - 15
2019 Days Camped - 34
Justice12t is offline   Reply With Quote
Old 09-20-2018, 08:14 AM   #5
I had the Correct Track system installed on my fiver because I worried about a slide bracket that was close to one of my tires. The system raised the trailer about 2 inches providing more clearance over the bracket and leveling the trailer when connected to the truck. I had the Forever Bushings installed at the same time. Very pleased with the result.
Hank, Dianna and two fur babies Cody and Bella
2016 F250 PSD CC/SB
2018 Crusader 338RSK
Windjammin is offline   Reply With Quote
5er
