I took my cable tester and put it on each line in my RV. Here is what I identified to a 2014 25bhss.
White is the satellite connector on the outside
Black is the cable TV connector from the outside
Orange wire with black electrical tape was the antenna
Orange cable was to the connector to uplink on the camping side of the Rv.
So after figuring out what was what, step 1 I powered up the dish with the powerbrick. I also mounted it behind the TV.
I attached the receiver and pointed it toward 101 and started to receive signal.
Next step I will build a jumper system with the Orange cable so I can connect to cable/ antenna and then bypass the power system when I want to use the satellite dish.
