Old 11-16-2014, 06:01 PM   #81
FreddieMac's Avatar
I took my cable tester and put it on each line in my RV. Here is what I identified to a 2014 25bhss.
Name:	ImageUploadedByForest River Forums1416182020.307661.jpg
White is the satellite connector on the outside
Black is the cable TV connector from the outside
Orange wire with black electrical tape was the antenna
Orange cable was to the connector to uplink on the camping side of the Rv.
So after figuring out what was what, step 1 I powered up the dish with the powerbrick. I also mounted it behind the TV.
Name:	ImageUploadedByForest River Forums1416182346.269551.jpg
I attached the receiver and pointed it toward 101 and started to receive signal.
Next step I will build a jumper system with the Orange cable so I can connect to cable/ antenna and then bypass the power system when I want to use the satellite dish.
FreddieMac is offline   Reply With Quote
Old 11-17-2014, 09:19 PM   #82
FreddieMac's Avatar
Next step, I drilled two holes and built a jumper. I put the jumper on the right using some 90 degree elbows.
Name:	ImageUploadedByForest River Forums1416280597.244991.jpg
Here is a picture with a jumper on the system.
Name:	ImageUploadedByForest River Forums1416280662.154737.jpg
I will need to make the hole a bit bigger.
Old 11-19-2014, 08:15 PM   #83
FreddieMac's Avatar
For it all buttoned back up and ready for testing tomorrow night. Hopefully I will have directv for this weekend's camp.
Name:	ImageUploadedByForest River Forums1416449648.425646.jpg
Name:	ImageUploadedByForest River Forums1416449659.687487.jpg
To make everything quicker to setup and take down, I added BNC connectors to everything.
Old 11-23-2014, 04:54 PM   #84
FreddieMac's Avatar
Test it all and it is ready to go.
Name:	ImageUploadedByForest River Forums1416783260.784380.jpg
Hope I can dial it in this weekend.
Old 11-23-2014, 05:01 PM   #85
Mr. Dan's Avatar
Attachment 66794
Way to go, FreddieMac!
I'm thankful my trailer was wired such that I didn't have to make all the mods you made.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 11-23-2014, 05:49 PM   #86
FreddieMac's Avatar
Thanks, I hope this post will help someone in the future.
Old 11-23-2014, 07:32 PM   #87
I bought the Winegard carryout portable antenna and chose the Dish network. Dish is a pay as you go month to month service. I just place the antenna were it can see the sky and it finds the satellites and I have TV.
mikelavonne is offline   Reply With Quote
Old 11-24-2014, 08:05 AM   #88
FreddieMac's Avatar
I went camping this past weekend and could not dial in the TV. When I got home yesterday, I set everything up to try an figure out the problem. I found the source of the problem to be me. I did not realize the tilt on the back was in increments of 2 instead of 1 so, I was set on 74 all weekend when I should have been on 72. Once I figured that out, I was able to dial the transponders into strengths of 90 and 100 at home. Tested the entire system. We are going out to tailgate this weekend, I will see if I can dial it back in. It seems this is a skill that requires a bit of practice, but once you have everything figured out, I was able to setup and dial in a signal in 10 minutes at home.
It is $30 per month for DISH versus $6 per month for Directv under my current contract. To get a tailgater for DISH for HD channels would have been $300 plus.
I was able to pull a used dish off the roof of my sister's house and between switching the LNB, all the cables and TRIPOD, I spent about $125 for my entire setup.
PLUS, the DW does not want to switch to DISH. If I were a DISH customer, I would have just bought a tailgater too.
