Disc brake Conversion questions
For those that have done a disc brake conversion , can you offer some guidance on a couple things I’m wrestling with?
Is it necessarily better to have 1/4” main line vs. 3/16”? The research I’ve done shows conflicting results, since you need reducers to the hydraulic brake actuator and the T-fittings. Titan’s brake line kit only offers 1/4” main lines for Triple axles.
Is mounting the HBA closer to the axles to shorten the main line more effective than upgrading to the 1/4” line?
I’ve also seen that it is advisable to keep the HBA wires no longer than 25’ and to use 10 gauge wires. If this is the case, I could mount the HBA in a compartment right above the front axle.
Finally, I’ve read a couple reviews that the Titan actuator has about a 1 second delay. For this reason, I’m considering the Dexter HBA. Thoughts?
Thanks!
2014 Freedom Express 320BHDS Liberty Edition 50th Anniversary
2005 F250 Lariat SuperCrew 6.0 PS Diesel
2004 Excursion Limited 4x4 6.0 PS Diesel
2000 Excursion Limited 7.3 PS Diesel Sold:crying
