Old 05-27-2016, 01:29 PM   #11
PapaE's Avatar
Looks high to me also. I am fighting that problem now. Few days ago, I put longer rear shackles on my truck... advertised as lower 2"... actual about 1.5". But that did help enough that I could, and did, drop the hitch 1 level (1")... and still have space between trailer overhang and truck bed... and I am about to go out and get it on level ground and check it. I need just a bit above 6" trailer-to-truck clearance to avoid them touching when I back down hill into back yard where I park trailer. I don't use air bags. Wish you the best... I have been towing with the nose a bit high (probably about how yours is in the pic.) till I can get this worked out.
Me & the DW
2016 Coachmen Brookstone 334RE Fifth Wheel
2015 Chevy 3500HD Diesel DRW Crew Cab 4X4 LTZ
PapaE is offline   Reply With Quote
Old 05-27-2016, 01:49 PM   #12
CaptnJohn's Avatar
Looks a little high ~ I'd try reducing the air in the bags but would not hesitate to tow that way and see how it feels.
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 05-27-2016, 01:52 PM   #13
Telstar's Avatar
If it's 6" your OK, but it would be better if it were level.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline   Reply With Quote
Old 05-27-2016, 02:45 PM   #14
Mr. Dan's Avatar
Originally Posted by Mojack View Post
The air bag on the truck are full....
What exactly do you mean by 'the air bag are full'? By full, do you mean maximum allowable pressure? How much air pressure do you have in the bag - somewhere between 20 and 50 lbs., maybe?
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 74 (booked = 11)
Old 05-27-2016, 04:41 PM   #15
We have never had a 5er, but we have had 3 TVs with air bags. The first set was on a Ram 1500 and we were carrying a Lance 8.5' slide-in camper weighing in at 1,850 lbs dry weight. When the dealer set up the camper, we had installed Firestone Ride-Rite air bags and aired the bags to 60 lbs. per the dealer's suggestion. That leveled the Ram and it handled fairly well. The point here is if you have your bags "full" to maximum pressure (100 lbs on the Ride-Rites), it may be too much. It will raise the back of the TV several inches. You may be able to find the sweet spot to level the 5er on bag pressure alone and not sacrifice handling.
PenJoe is offline   Reply With Quote
Old 05-27-2016, 05:11 PM   #16
Oaklevel's Avatar
Nose high best position is to be level.
Find something like these instructions for your hitch......
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 05-28-2016, 09:03 AM   #17
Boots49's Avatar
Send a message via Skype™ to Boots49
Can't tell 100% from the image you posted, but to me it looks as though your hitch is not centered on the rear axle of the truck. That would be the first thing to check and then absolutely lower the nose. You are riding nose high and run the risk of bottoming out on the back. Good luck!
Al & Susanne
Aka: Puss 'n Boots
Wildcat 31 TS - Silverado 2500 DuraMax Diesel
Tip of the Day: Stay safe, have fun and never leave the cat out in the rain!
Boots49 is offline   Reply With Quote
