Old 05-26-2016, 02:15 PM   #1
Mojack's Avatar
Does the height look right?? Please look
How does the height look to you experienced folks out there. The air bag on the truck are full and the hitch is all the way down. I am wondering if the front is too high for safety reasons. I have about two holes left on pin box. So only about three inches of downward movement. Please let me know Click image for larger version
Name:	ImageUploadedByForest River Forums1464290070.806949.jpg
Mojack is offline   Reply With Quote
Old 05-26-2016, 03:06 PM   #2
Elkhounds's Avatar
Looks nose high to me. Measure from the ground to the bottom of the frame at both front and back of trailer. That is about the best way to check it if the road is not exactly level. Still need a flat road to do but it won't have to be level.
2015 F-350 Platinum 6.7 PowerStroke
2017 Columbus 320RS
Elkhounds is offline   Reply With Quote
Old 05-26-2016, 03:24 PM   #3
If the truck is level, yes, the FW Is nose-high. Move the pin box up, but you need no less than 5-6" between the truck top rails and bottom of the FW.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 05-26-2016, 03:28 PM   #4
Mojack's Avatar
Can I safely tow it this way? I'll need to get it home where I can adjust the pin box?
Old 05-26-2016, 03:36 PM   #5
Head Rambler
That's not terribly nose high. You'll be fine to tow it like that. Just be careful of humps and swales.
It doesn't look like you have a lot of room to lower the nose without compromising the bed to overhang distance. You may wind up adding a lift kit to the RV axles.
Gotta go campin!
Old 05-26-2016, 03:40 PM   #6
clr
In my opinion it is save to tow. But I would keep the unit as light as possible and go slow. I have seen many worse that this blowing down the interstates. When you get the unit home I would lower the pin box to get this unit more level. But as others have states you need at least 6 inches between the truck bed rail and the bottom of the 5th wheel.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 05-26-2016, 05:58 PM   #7
I think it's safe to tow; I'd do it.
Old 05-27-2016, 11:48 AM   #8
hicksie's Avatar
From the picture it appears that you have to of clearance between the rear tires on the truck and the fender you might want to readjust the air pressure on tour airbags I usually only run with 20psi in my air bags with our Crusader and have never bottled out yet on the interstate bumps and depressions driving at 65-75 mph
Les Hicks
Canadian Army,Commercial Motor Vehicle Enforcement,
Supervisor Courts Services (Retired)
Living the dream with Carol my best friend/Wife for 50+ years2011 F-250 6.2ltr 2 WD ext cab / 2015 Crusader 350 touring edition
hicksie is offline   Reply With Quote
Old 05-27-2016, 12:26 PM   #9
2007 WildCat 32QBBS
05CrewDually's Avatar
Safe to tow, yes.
Check top of bed rail to 5er, you only need 5-6" for normal use.
If it is still nose high, check the leaf spring eyelet mounting points. If it's on the upper hole then you can drop to the second lower hole which in turn will lift the back of the 5'er making it closer to level.
05CrewDually is offline   Reply With Quote
Old 05-27-2016, 01:14 PM   #10
Kenny kustom's Avatar
What's the tow vehicle?
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
