Old 03-21-2016, 09:16 PM   #1
Dometic Frig Error E0
After letting the battery run down with the frid on, now I have an error message E0. The battery is charged and I still have the same error message. I have unplugged it to let the frid reset, but did not help. Any ideas of what might be wrong?
kdowdy is offline   Reply With Quote
Old 03-21-2016, 09:22 PM   #2
TURBS's Avatar
Domestic Frig Error E0
Simple Google search
http://www.dometic.com/QBankFiles3/E...nual_17595.pdf
Page 13
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 03-21-2016, 09:37 PM   #3
I have the manual and know what the error message means but thought someone might have had the same issue and could tell me what it takes to fix it.
Old 03-22-2016, 05:55 AM   #4
TURBS's Avatar
What did you you "unplug"?
You need to pull the fuse in the distribution panel for the fridge since the refrigerator control board is 12 v
2008 2500hd Duramax
2015 Columbus 320RS
Old 03-22-2016, 07:14 AM   #5
I unplugged the frig in the back, which is what Domestic support told me to do. I will look for a 12v fuse in the fuse panel and pull it. Thanks.
Old 03-22-2016, 07:55 AM   #6
TURBS's Avatar
Respond back with findings.
2008 2500hd Duramax
2015 Columbus 320RS
Old 03-22-2016, 12:31 PM   #7
Had similar problem, did not clear until I disconnected all connections in rear of fridge and let it sit for 10 minutes or so and reconnected. Work fine the rest of the camping season.
bobkatz5 is offline   Reply With Quote
Old 03-22-2016, 12:35 PM   #8
TURBS's Avatar
The e0 is loss of communication.
The battery going dead caused the lack of communication.
Once reset it should be fine
2008 2500hd Duramax
2015 Columbus 320RS
Old 03-23-2016, 11:11 AM   #9
The frig is working now, thanks to everyone for the thoughtful suggestion. After disconnecting from land power and disconnecting battery with disconnect switch and waiting an hour everything is working again. Learn something new every day.
Old 03-23-2016, 11:25 AM   #10
TURBS's Avatar
Thanks for the update!
Happy camping!
2008 2500hd Duramax
2015 Columbus 320RS
dometic
