Old 03-16-2016, 07:27 AM   #1
Draining after sanitizing
New owner with a noob question. I've read few articles about sanitizing our water systems. They all state drain and flush. My question, will the bleach water solution stain the concrete or kill the lawn?
I used 2oz per gallon. After running a lot through the lines and letting it sit overnight I've topped off the tank to dilute the mixture before draining. Just want to know if it's OK to drain in my driveway or go to a dump station.
Thanks for helping a newbie,
Chris
H8Bogez is offline   Reply With Quote
Old 03-16-2016, 07:45 AM   #2
Drain in the driveway.
BBQGUY is offline   Reply With Quote
Old 03-16-2016, 07:51 AM   #3
nomad297's Avatar
In California you would be dumping toxic waste and would be subject to a huge fine and be responsible for all environmental cleanup costs.
Bruce
nomad297 is online now   Reply With Quote
Old 03-16-2016, 07:51 AM   #4
Kaadk's Avatar
Depends what you're draining. The FW tank is probably ok, though I'd drain to a pail and the dump in the house if you're concerned.
The neighbours would frown on draining the black and/or grey tank so those get dumped at the first camping trip of the year.
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 03-16-2016, 08:02 AM   #5
Thanks everyone...I especially appreciate the toxic waste warning for CA residents. Made me laugh thinking of my native state.
Old 03-16-2016, 08:03 AM   #6
Just to make sure how much bleach you used. Should be: 2 oz. bleach per gallon of water to make a solution. This is enough to treat a 15 gallon tank. Add the solution and then fill the tank with water. E.g., if you have a 30 gallon FW tank you would end up with a TOTAL of 4 oz. bleach in your filled tank.
Once you've drained the FW and gray tank in your driveway/lawn you'll need to fill and flush several times to get rid of the chlorine smell. This will further dilute the bleach.
2015 Shamrock 231KSS, Oyster shell
2016 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017
CNYCamper is offline   Reply With Quote
Old 03-16-2016, 08:13 AM   #7
jeff64's Avatar
Never have I really measured the bleach. Maybe a cup or so/ tank (36-55 gal.). I don't believe it is that critical. But then that's the way I cook too. I'll leave it in a couple hrs. then drain and flush. Leaving it in too long is probably worse. I will tell you though, it brings a few worms up when you drain it all out. Haven't noticed any ill affects to the grass or ashpalt
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 03-16-2016, 08:15 AM   #8
SeaDog's Avatar
The diluted mixture you used will not hurt anything by draining in the drive. Some folks continue to flush and drain. Myself I use a heavier mixture then you used and let it set for 24 hr the drain and flush one time.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-16-2016, 08:18 AM   #9
TURBS's Avatar
1/4 cup per 15 gallon is the ratio.
I dump the remaining bleach/water solution on the ground then refill.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
drain
