Originally Posted by rockfordroo
Dry weights are for suckers; the manufacturers and dealers just use it to sell ignorant people more camper than they should be buying for their tow vehicle size. Don't even think about dry weights. The camper will never weigh that number ever again. Use GVWR. If you can handle the GVWR, you'll always be OK. You can find the GVWR on the sticker on the left front end of the TT. See mine below.
EXACTLY. Dry weight is the weight of a build without any options, basic build, no batteries or propane fill, NO OPTIONS
and... Batteries are a dealer installed item, not factory installed.
I know, I'm personal friends with 2 RV transporters who make good money delivering RV's all over the country to dealers.. I'd do it myself but I have enough on my plate with farming and doing 'honey do' stuff around the farm.
Nice retirement job for someone who has nothing to do and wants a good income. Of course there is an investment involved... A late model 1 ton DRW pickup and the necessary hitches installed (fifth wheel and Class 5 receiver)
Always keep in mind that your 'New' RV has been pulled down the road by a transport contractor and... The farther away from the factory the selling dealer is, the farther your 'new' Rv has been towed, so things like tires and brakes and suspension components are not 'new', they have been used.
One reason why I bought my RV from a dealer close to the factory, mine was a lot 'newer, than say getting it from a dealer a thousand miles from the builder. In my case, the dealer was 15 miles from the factory.
That don't apply too all RV's. The smaller TT's, A frames, TC's and (I think) even the smaller 5er's are trailered in multiple units on specially built transport trailers, but, the bigger 5er's and pull behind's are pulled by the transporter, down the highway to the dealer's lot.
Si it may be 'new' inside but outside, it's not new, it's used and maybe somewhat abused. They guys I know are paid mileage so they want to 'get it there' ASAP and get back for another pull. They run hard and fast. How it works, unlike a new car, where all cars are delivered in quantity on a car hauler. The only mileage accumulation a car or pickup truck gets is the distance from the exit of the assembly line to the holding lot and then either on a car hauler trailer or loaded on rail to another marshaling area and then on a transporter, typically 15 miles or lees total until it's sitting on the dealers lot.
Not so with an RV. That RV you bought may have a few thousand miles on it (depending on where the dealer is in relationship to the factory).. Ever wonder why no RV has a 'Hubometer' on it? A hubometer records mileage. If you knew the actual mileage on the running gear, you might not buy it...
New, might not really be new on the running gear.... Things to ponder.,
