08-23-2015, 09:56 AM
electric heater
Many camp grounds I go to have shore power. As the weather gets colder I plan to continue camping but don't want to use my furnace unless it becomes necessary. Why use my propane if I am already paying for electric?
So my question is how big of an electric heater do I need to keep my 5er comfortable? Don't need 75 - 80 degrees, 68 would be fine during the day. I am talking about an 08 32 foot Rockwood Signature Ultra-lite 8280SS. Nothing real big and needs to be able to run on 15 amp circuit. I see the ceramic heaters seem to be popular. Weight is a consideration. Would like something that will work even when it gets to 15 degrees outside and understand I might need to run two at those temperatures. I am sure there are members that do this so am looking for suggestions.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
08-23-2015, 10:06 AM
In sizing you need to consider what else may be on that same 15 amp circuit. A 1500 watt heater draws 12.5 amps in itself when on 120 volt power supplies.
The way you can do the amp math is watts = volts x amps
Or amps = watts divided by volts
1500 watt heater = 120 volts x 12.5 amps.
2011 Flagstaff 831 RLBSS
08-23-2015, 10:08 AM
Georgia Rally Coordinator
Basically if you kind of know your square footage then buy your heater accordingly and staying within the amp rating. Ceramic heaters are the best. I use a small Ceramic heater in our 35 ft camper and are temps are around 40 or so and it keeps it bearable. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
08-23-2015, 10:24 AM
Trust me I understand all that. What I want to know is how big of a heater, or heaters, do I need? What do members use that have worked well for them? There are only 15 million different ones to chose from out there, LOL. Sense it is just the dog and I, I will know what is plugged into the circuits.
Jim
George Bernard Shaw
08-23-2015, 01:57 PM
Explorer
I have two small Honeywell(16x6x6), just $30 guys from Walmart. They don't have perfect thermostat just a rang of heat that you kind of get to know. For us one works good in the day or over kill to heat the bathroom for a shower, at night we use two because our bunk house is on the opposite side of the camper.
We like it cold though, 54-ish at night, 72 to get up and get dressed and 68-ish in the day and we're happy campers. We have never camped at temps below 24F at night, normal cold for us is 45.
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
08-23-2015, 02:09 PM
We have the Eden pure 1200 watt heater works great a little expensive but originally got for another purpose. We do like the fact that the outside surface does not get hot, since we now use it camping would not want anything else.
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
08-23-2015, 09:10 PM
I use the 1500 watt heater on our fireplace and ad a second 1500 watt in the bedroom when needed to heat our 42' fiver. Stays fairly comfortable and if really cold will turn the furnace on to help.
08-23-2015, 09:27 PM
Location: Alberta - East of the Rockies, West of the Rest
What a timely question, the grass this morning had a white sugar coating and felt kind of crunchy - no kidding .
We use a Presto Heat Dish (Costco many years ago) with infinite temp. settings and tip over protection.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
08-23-2015, 09:38 PM
I have to add that the heatpump on the AC is our first choice as long as the temps are above freezing. This morning it raised the temperature from 15 C to 22 C in under 15 minutes - I was impressed since the outside temperature was only + 1 C but the sun was out.
Sorry, to lazy to convert
Ordered: 2021....
08-24-2015, 03:41 AM
We found the secret to using electric heaters is to run them on the low heat setting...they last a long long time that way.....and don t get hot for potential hazard...
usually one is enough and supplement with camper heat....but sometimes two are required on low heat in 5 er....one upstair and one down...on two different circuits...
they seem to draw around 7-8 amps on low each....well within the 15/30 amp limit so you can still use micro or coffee pot without tripping a breaker....there again common sense applies which the human race has, but doesn t use most of the time.
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
08-24-2015, 05:15 AM
Use the furnace to get your unit warmed up, then a cube heater can maintain unless it's really cold. Just set furnace to a lower setting to kick on if elec heater can't keep up. We usually set it about 65°
2018 Forester 3011 DS
08-24-2015, 08:28 AM
Tip over protection is a must due to my 4 legged baby. I think all modern electric heaters have it now. If not they should.
Jim
George Bernard Shaw
08-24-2015, 08:41 AM
My previous 5er had a heat pump attachment to the AC but this one doesn't. Wish it did but don't think I can add it to this AC unit. If I could that would be my first choice.
That is why I decided to look at the ceramic heaters. Figure I can put a portable on the kitchen counter and at night put the fan on continuous to heat the bedroom area.
I can do the conversions for you. 15 C to 22C is 59' F to 72 F, +1 is 34 F.
Jim
George Bernard Shaw
08-24-2015, 09:08 AM
Looks like your Rockwood is similar to mine so guessing it has a 30,000 btu furnace. Keeping it set around 63 to 65 just in case is a good idea. With a good ceramic heater it probably won't be needed though. Just hate to waist the propane if I am paying for the electric.
I would run the furnace while setting up to get to a decent temperature. It shouldn't take long to get the trailer warmed up.
Jim
George Bernard Shaw
08-24-2015, 09:14 AM
I agree... why not use the CG power for heating (unless metered).
Here in the Pacific Northwest a good electric heater is nice to have.
It provides nice dry heat with air movement, several settings, quiet running, reliable and safe.
This is what we use: Caframo True North Deluxe Space Heater <link
I have it set @ the frost protection setting during winter lay-up.
It is just enough to keep it dry with air movement as it cycles on cold winter days.
Tip: I placed a strip of reflective tape across the top front edge to prevent giving it a field goal (kicking it accidentally) .
Hope this helps
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~ Trail Air - Tri Glide Pin Box 2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles Edge programmer, 4" SS exhaust turbo/back, Tru-Cool Max Trans Cooler, Bilstein Shocks Vancouver Island, B.C., Canada
08-24-2015, 09:27 AM
If I'm on shore power I use 2 ceramic heaters 1200 watt on low and 1500 on high setting. I keep one in the bedroom on low and the other one down stairs on low or high and then set the temp on the electric fireplace to help the ceramic ones if its needed. Keeps us toasty. If we are boondocking during the day and the sun is out I'll run one of the ceramic heaters on low off the Solar power/inverter while running the central propane heater. At night we just use the central propane heater till the sun comes up the next day. I can make 35 amps off my solar panels so we can use 1 ceramic heater all day off the inverter pretty much to supplement the central propane heater. If its cloudy then its all from the propane central heater.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
08-24-2015, 09:28 AM
I just run the furnace, Camp in comfort 😎
2016 Vibe Extreme Lite 221 RBS
2013 Silverado 2500 HD Duramax
08-24-2015, 09:30 AM
We use this. Love it.
08-24-2015, 09:37 AM
OK you win...
08-24-2015, 09:52 AM
We purchased a heater like this about 8 years ago and have used it in our house and in our RV each year. During the camping season it stays in the fifth wheel and then when we close up the RV, it comes in the house for supplemental heat.
It works great and is infrared, so there is little to no chance of causing a fire by getting too close to furniture or material. It is fan forced and distributes the heat well.
http://www.northerntool.com/images/p...64_400x400.jpg
