Electrical surges in brand new Rockwood Mini Lite 2507S
Getting ready for my maiden voyage in my new 2019 Rockwood Mini Lite 2507S.
I was plugged into shore power for a day and inside packing stuff when I noticed the inverter cycling over and over again like it was charging the battery.
About 4 seconds charging, 4 seconds off.... over and over.
I made sure everything is turned off and it keeps doing it.
I unplugged from shore power and have just the dome lights on inside.
I notice that the dome lights dim for 4 seconds then full bright for 4 seconds ... over and over. So, something is turning on and off.
I turned off the refrigerator and it still does it. The water heater has the electrical switch off.
The WiFi Ranger that came with this from the factory runs on DC I turned it off too.
Called a hotline and what do you know, they helped me figure it out.
On the main panel for the switch that controls the dome lights, the wire was loose. I tightened it and it stopped going bright and dim. Just bright.
The question is, why did it go on and off like that if it was loose? I can see intermittent but what the heck?
Anyone?
