EMS-HW50C Install Sabre 36QBOK
So I decided to look at what kind of install time I'd be looking at for the new EMS. I pulled the panel since I don't have access through any of the entertainment cabinets.
Can anyone confirm that I just need to tap into the big black supply power cable (that is secured with the gray clip in the last photo) going into the back of this panel? There is enough slack to that wire that if I cut it I could just use both of the cut ends rather than using a pigtail to the panel. That way I also wouldn't have to rewire anything on the panel...
As a side note, I wondered where they had pulled the power for my vacuum system, but they just put a 110 plug on the back side of the panel and plugged it in there...
Ugh... any idea why it rotates some pictures 90 degrees? Even if I rotate it and save it before hand then it flips it 180...?
