Old 05-13-2016, 11:38 AM   #1
EMS-HW50C Install Sabre 36QBOK
So I decided to look at what kind of install time I'd be looking at for the new EMS. I pulled the panel since I don't have access through any of the entertainment cabinets.
Can anyone confirm that I just need to tap into the big black supply power cable (that is secured with the gray clip in the last photo) going into the back of this panel? There is enough slack to that wire that if I cut it I could just use both of the cut ends rather than using a pigtail to the panel. That way I also wouldn't have to rewire anything on the panel...
As a side note, I wondered where they had pulled the power for my vacuum system, but they just put a 110 plug on the back side of the panel and plugged it in there...
Ugh... any idea why it rotates some pictures 90 degrees? Even if I rotate it and save it before hand then it flips it 180...?
ID:	107741   Click image for larger version
ID:	107742   Click image for larger version
ID:	107743   Click image for larger version
wentcamping is offline   Reply With Quote
Old 05-13-2016, 11:42 AM   #2
Elkhounds's Avatar
Be sure trailer is not plugged in. Then you should be able to cut that big black wire and put it in and out of the EMS. On mine I pulled the wires out of the control panel because I didn't have enough slack. Very simple to do.
2015 F-350 Platinum 6.7 PowerStroke
2017 Columbus 320RS
Elkhounds is offline   Reply With Quote
Old 05-13-2016, 11:49 AM   #3
Perfect! Thanks for the info.
Old 05-13-2016, 12:58 PM   #4
head gamez's Avatar
That's it. I think you will find it easier to pull the cable out and attach it to the input of the ems and use a short piece from the hardware store to come from the output side to the panel. Working in that space will create issues with routing / installing the cable in the EMS.
2016 Sandpiper 376BHOK
2500HD Chevrolet
head gamez is offline   Reply With Quote
Old 05-14-2016, 08:03 PM   #5
Jimsue's Avatar
X2, Headgames.
2015 F350 Lariat Crewcab DPS SWD 4x4
2013 Sabre BKOK 31
andersen ultimate 5th wheel hitch
Renogy Solar Suitcase
Progressive Industries EMS
Sea Eagle 420 Tandem Inflatable Kayak
Jimsue is offline   Reply With Quote
Old 05-14-2016, 08:22 PM   #6
Kenny kustom's Avatar
Way easier to get at it through the basement.
Name:	ImageUploadedByForest River Forums1463275315.972664.jpg
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Kenny kustom is offline   Reply With Quote
Old 05-15-2016, 10:21 PM   #7
Kenny - that does look like the way to go. I was in my basement and had decided to take off the panel in the center in order to access that area. I can't believe they aren't required to do some type of cable management and that they don't even try to clean up the shavings etc when they are done.
It is no wonder there is hardly and QC to these units, it would be almost impossible to find a problem by inspection unless you were trying to find the specific problem.
sabre
