Old 05-13-2011, 03:03 PM   #11
sherdep's Avatar
I have gotten a reply saying he got my pictures and he will get back to me but havent seen a respone as of yet - I will let you know what he says - if I do not hear from him on Monday - he will be getting a phone call instead of an email.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-13-2011, 03:18 PM   #12
Location: Canandaigua,New York (The heart of the Finger Lakes)
My L-brackets look the same....we've only had our equalizer for 8-months. I have a spare also ! but as i said they look just like yours !! Hmmmm waiting to hear what they say to you !! let us know !!
David & Annamarie & 2-Pugs (Fatty and Harley)
2011 Rockwood Windjammer 3065
2011 Ford F-250 6.2- V8
2011 Hensley Arrow "NO-SWAY" Hitch
BigRed is offline   Reply With Quote
Old 05-13-2011, 03:24 PM   #13
M109Rrider's Avatar
Perhaps I vaguely remember mine being the same way. I can see how twisting the truck/camper, porpoising or driving over something like entering parking lot with a step up could cause the bars to put pressure straight up on the L pins. Think of how you use your tongue jack to lift the bars off the L brackets....really don't need to go up much further before they contact and put pressure on the L pins...ya know?
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 05-13-2011, 04:45 PM   #14
sherdep's Avatar
Ok well I decided to call and didnt give him till Monday since I am taking it out again this weekend.
Here is what he said,
My L Pins are wearing great - they will have three wear marks on them - the L pins are there to keep the bars from sliding to the side and out of the pocket - not so much as up and down since they have alot of pressure keeping them down on the L Brakcets.
He also said he has seen L Pins bent back worse then the one's I have now.
Told me I should paint the Bars so they dont start to rust.
Also made mention about the possibility of the hitch itself is flexing - he said it was common on Chevy / GM but doesnt recall the Dodge's - This past weekend I did lose the cover that is right above the hitch so there is a possibility it is flexing.
He said by the pictures I sent him the front looks a little high so he made a recommendation to add a washer to drop the front of the tow vehicle a little.
He asked me if I was greasing the hitch head - I said yes with the Equalizer special grease - he said it was axle / wheel bearing rated grease if I didnt want to buy there brand - I could use another brand.
I also asked him about the Hitch Head and after adding the washer how to set it up - tighten the large bolts to like 320 lbs and then do the set screw underneath to just tight with a 1/4 turn and then load the trailer on and tighten the set screw again once the bars were in place and it was on the shank.
Old 05-13-2011, 07:06 PM   #15
grhodes50's Avatar
Thanks sherdep.
That's good info. Thanks for contacting Equal-i-zer and sharing what you learned.
Gary & Trish
2018 Nights Camped - 5
Old 05-13-2011, 07:32 PM   #16
sherdep's Avatar
Originally Posted by grhodes50 View Post
Thanks sherdep.
welcome and if what I am learning helps someone else then things are good besides I was asked to post what was said and share the info - I does put my mind at ease now knowing it is normal and it isnt a huge setup issue
Old 05-13-2011, 08:43 PM   #17
backin15's Avatar
Originally Posted by lbrjet View Post
Adding a washer transfers more weight to the front of the truck and to the trailer axles. The front height of the wheel wells should the same hitched and unhitched, or slightly higher when hitched. If they are the same then don't add a washer.
Are you sure you are experiencing sway, or just normal movement? If the trailer just moves around a little then that is normal.
Also, I do not think that the 1000lb and 1200lb bars are interchangeable on the same hitch head. Measure the diameter of the bars to double check that they are the same width. The bars should fit like a glove inside the sockets.
So the bars should fit in the socket with little or no play? Mine have quite a bit of slop and I have been wondering if it is normal. I have had it for 7 years so I can't remember if the slop was there when it was new.
backin15 is offline   Reply With Quote
Old 05-13-2011, 08:53 PM   #18
sherdep's Avatar
when you put the bar in the square hole there isnt much play at all - the only play you will have is side to side since you have to swing the bars over to the L Brackets.
I am going to be hooking my truck up to my trailer either tonight or tommorow and will let you know a forsure answer on your question but from what I remember there shouldnt be much slop
Old 05-21-2011, 09:23 PM   #19
backin15's Avatar
Mine have quite a bit of slop up and down. I wonder if it is the hitch sockets or the bars that are causing the play?
Old 05-22-2011, 08:50 PM   #20
sherdep's Avatar
my bars have play in them too - as long as they are solid when you pop them up onto the L Brackets you will be fine - one thing I would check and make sure if that the bolts that hold the bars are torqued to - I think 45 ft Lbs if I remeber correctly
