Old 03-10-2016, 09:42 AM   #51
Brother Les's Avatar
Originally Posted by atcbrownie View Post
4400 pound axles by the way
The 44,000 pound axle is a hybrid axle.
It has the larger beam size (52,000 pd and up axle) of 3 inches around.
But uses smaller hub and brakes of the 35,000 pound axles (tube size less than three inches)
The brakes are 10inchs for the 44,000 pound axle and down.
the 52,000 pound and up brakes are 12 inches.
So... the spindle, hub and brakes goes to the 35,000.
The beam, goes to the 52,000.
Brother Les
Old 03-10-2016, 02:59 PM   #52
Hey now,are your Sure on these Weights you are Posting? You are talking some BIG #'s! Youroo!!
Old 03-10-2016, 03:24 PM   #53
Members
Tommy Joann's Avatar
I am very sorry to all! I posted some erroneous info about nev-r-adjust brake adjustment procedures. I have since learned that the drums have to be rotating forwards in order for the adjusting mechanism to work. Please forgive my stupidity!
2018 Salem 28RLDS Showstopper Package
2015 Chevy Silverado Crew Cab LT Sport
Husky Centerline WDH
Tommy Joann is offline   Reply With Quote
Old 03-10-2016, 03:33 PM   #54
[[[[Hey now,are your Sure on these Weights you are Posting? You are talking some BIG #'s! Youroo!! ]]]]]]
ooopps, Drop a zero on each number....
Brother Les
Old 03-10-2016, 03:44 PM   #55
SilhouettePenny's Avatar
Originally Posted by TURBS View Post
Manually adjust from behind through a oval hole that you may need to take a rubber plug out of.
A flat tip screw driver or a drum brake spoon will move the wheel to adjust as you rotate the tire.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
After engaging the brake spoon in the star wheel (put a flashlight in one of the oval holes and adjust thru the other) A downward motion will tighten and moving the screwdriver upward will loosen, tighten down-loosen up.
2017 F350 Dually 6.7 Diesel
2014 Silhouette 299 RKDS
Nights Camped 2017 - 63
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 03-10-2016, 05:45 PM   #56
You may have to use another small screwdriver to move the lever out of the way to loosen the star wheel.
2011 Traverse LT, 3.6L, FWD
Old 03-17-2016, 08:02 PM   #57
V-Lite Fun's Avatar
How many miles do you feel a set of trailer brakes should go? I have about 10,000 miles on mine. I checked them today and they have about 3/16 pad left. I'm planning to do 10,000 plus this summer so I guess I had better have them changed.
Forest River Flagstaff V-Lite 26 WRB. 2015 Ford F 250 diesel, Hensley Arrow Hitch
http://rvadventuresofpetedoll.blogspot.com
V-Lite Fun is offline   Reply With Quote
brakes
