Old 08-13-2016, 07:33 PM   #11
justpassinthru's Avatar
Question
Always hear go to the scales weigh the Tow Vehicle and then trailer separate then both together with all your people and full load, but on my travels i see wegh stations but are we allowed to enter and do all this? When it specifies on tractor trailers, so what does everyone else do ? Thanks Jim
justpassinthru is offline   Reply With Quote
Old 08-13-2016, 07:52 PM   #12
Mrs Evans's Avatar
I wouldn't go to a weigh station but there are CAT scales at certain truck stops.
Michelle Evans
Katy, TX
2011 Carriage Cabo 341
2014 Wildwood 231RBXL - Traded Her In
2016 Days Camped = 5; Reserved = 14 so far
2015 Days Camped = 24 / 2014 Days Camped = 23
Mrs Evans is offline   Reply With Quote
Old 08-14-2016, 09:01 AM   #13
Originally Posted by Mrs Evans View Post
Would this work with a 6.5 short bed? Also, the fifth wheel we're interested in is an older model not designed for short beds so we will definitely need a slider hitch of some type. I do like the idea of a hitch that is easy to put in and out of the bed
Had a dealer tell me he never knows if a slider is needed, or not, until the combo is hooked up, and my experience tells me the same. Had a 2004 F150 with the 5-1/2' bed and definitely needed a slider. Didn't think I needed one with the 6-1/2' bed in my F350, but I do. All the auto sliding hitches are heavy and a two-man job to remove and install, so you need to keep that in mind.
phillyg is offline   Reply With Quote
Old 08-15-2016, 09:49 AM   #14
Mrs Evans's Avatar
Yep, I think we're going to go the non-slider route and just make sure it's compatible with a sidewinder in case we decide it's needed.
Thank you!
Michelle Evans
Katy, TX
Old 08-15-2016, 12:48 PM   #15
Mrs Evans's Avatar
Thank you!
Well, so much for this idea, lol! My DH decided on a B&W Companion Slider Hitch - might be a bit heavier but oh well!
Michelle Evans
Katy, TX
Old 08-18-2016, 03:16 PM   #16
Your husband made a good decision. With a 5.5 bed you will need the slider.
I have a GMC with 6.5 bed and radius fifth front and it makes 90 degree turn without using the slider although i have it, but it's close call..4
Michel
micalo is offline   Reply With Quote
Old 08-18-2016, 03:23 PM   #17
Mrs Evans's Avatar
Michel
We are totally upgrading our tow vehicle and although it will still be considered a short bed, it'll be a 6.5 bed as well We may never 'need' the slider but we'll have it just in case
I'll update my signature when the deal is done
Michelle Evans
Katy, TX
fifth wheel, hitch, wheel
