Old 07-11-2013, 11:42 AM   #1
CCRVOC
Ramblin Recks's Avatar
Fifth Wheel Hitch-up
Curious as I have yet to hook-up a fifth wheel (I will in a couple of weeks). I saw a video on the RV Travel.com site that said to connect your 7 pin connector to the TV before trying to hitch-up. He said this way you could use trailer brakes to keep from rolling. Being the newbe that I am to fifth wheels, I'd like to get your opinon on this, what say you?
Reck
Ramblin Recks is offline   Reply With Quote
Old 07-11-2013, 11:44 AM   #2
TURBS's Avatar
Reck
I do this frequently when hitching up if wheels are not blocked.
Especially at home as its not blocked there.
Turbs
Old 07-11-2013, 11:48 AM   #3
Fulltime family RVer
I *always* have my wheels chocked if the camper isn't attached to the truck. I trust my chocks.
BUT- I can definitely see the value in hooking up the umbilical cord before hitching up.
ependydad is online now   Reply With Quote
Old 07-11-2013, 11:50 AM   #4
Not a bad idea, but I would find it awkward to reach down to my brake control to activate the trailer brakes, while at the same time looking back to hit the fifth wheel pin.
I use Bal X-chocks on my camper tires, and that serves the same purpose.
bakken is offline   Reply With Quote
Old 07-11-2013, 11:54 AM   #5
Always have Bal X Chocks installed when I hitch up except at home when it is against the wheel chocks. Removing the Bal X Chocks is the last thing I do on the final walk around checking lights.
Old 07-11-2013, 11:56 AM   #6
B47
Reck
I guess this would work if you needed extra chocking. We have never found it necessary due to having the 4 wheels chocked and the front landing gear down when hooking up.
One possible problem I could see is if for any reason you have to pull forward to make another attempt to hook up and you forget to disconnect the cord before doing so - well you can visualize what might happen.
B47 is online now   Reply With Quote
Old 07-11-2013, 11:59 AM   #7
Dave_Monica's Avatar
Doesn't the camper wheels still go a 1/4 - 1/2 turns before the brakes are engaged?
Dave
Old 07-11-2013, 11:59 AM   #8
Oh, hey - I just did that MONDAY. Went to pull the truck forward after parking the camper and watched both my emergency breakaway and umbilical cord pop out.
I was just having one of those trips...
Old 07-11-2013, 12:03 PM   #9
JDWeir's Avatar
I will have to agree with B on this one... About the only hook up/disconnect "oops" I have committed in several years of towing a 5th wheel is driving away from the trailer after forgetting to unhook the cord... it plays havoc with the truck side connector.
Had to replace the whole truck side part of the connection. Imho, using the umbilical when hooking up *could* cause the problem B stated.
TV, 2000 Dodge RAM 2500 Quad cab short bed, Cummins 5.9, Edge Comp, Gauges.
5ver, 2011 Palamino Sabre 31 RETS.
JDWeir is offline   Reply With Quote
Old 07-11-2013, 12:06 PM   #10
B47
Much damage?
Remember some time ago there was a video showing a new style umbilical cord connector that was designed to release the cord if it was not pulled out even at a 90 degree angle? I never heard anymore about it and was skepical about that part.
