Old 09-24-2015, 06:01 PM   #31
MacDR's Avatar
ID:	89767Click image for larger version
ID:	89768Click image for larger version
ID:	89769Click image for larger version
Oops threw in some firewood...
Greetings from Wisconsin
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Day's Camped 2018 "14"
You can find us: Egg Harbor Campground 7/9 - 7/11
MacDR is offline   Reply With Quote
Old 10-20-2015, 10:18 AM   #32
Does this help keep the camper from moving when set up? We have anywhere from 1-5 kids camping with us and seems like the slightest movement from them rocks the camper. I have a 2016 320A Vengeance and I had a 2012 21RR and both move a lot. I have the front stabilizer jacks and just the two rear scissor jacks.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=2
Electra glide is offline   Reply With Quote
Old 10-20-2015, 10:28 AM   #33
Only for vertical movement. Must have telescoping stabilizers going from frame to the jack bottoms to eliminate side to side motion.
Old 10-20-2015, 12:30 PM   #34
Our Steadyfast system took out both front to back and side to side. I also use X Chocks, which I had prior to my Steadyfast. See my pictures at the front of this thread.
Sierra360PDEK is offline   Reply With Quote
Old 10-20-2015, 12:40 PM   #35
muddyrode's Avatar
we have the JT's front and back on the 2012 wildcat 32RL and love them, much steadier with them on
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 10-20-2015, 12:44 PM   #36
leefl's Avatar
As mentioned previously, the side-to-side movement is greatly reduced with the cross-arm stabilizers, but there's still a fair bit of bounce and front-to-back movement.
I'm still planning on adding some BAL/JT stabilizers front-to-back, likely on both the front jacks and rear stabilizers.
I'm also considering mounting some stabilizers/jacks near the wheels.
Since the main chassis is pretty well covered, and I'd like to avoid removing too much of it (and would prefer to use bolts rather than self-tappers), and since many scissors-jacks top-out around 24" and my chassis is at 23", I was thinking of using scissor-jacks on the suspension sub-frame (whether the jacks are bolted on to there, or just free-standing.
Any reason why I should avoid using scissor jacks on the sub-frame ? (whether attached or free-standing)
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 10-20-2015, 07:10 PM   #37
I have used Steadyfast and JT Strong Arms and liked the Steadyfast much better. Both systems still has some wiggle so I have since added a kingpin tripod and X chocks. Each addition helped more and more to take wiggle out.
Anyone with Ground Control tell me does that take the wiggle and bounce out?
Dinostop is offline   Reply With Quote
Old 10-20-2015, 07:17 PM   #38
Originally Posted by leefl View Post
...Any reason why I should avoid using scissor jacks on the sub-frame ? (whether attached or free-standing)
I traded Herk a set of bolt on scissor jacks for his bent rear stab jacks. They worked great for me and I think Lou is satisfied with them.
Name:	Axle scissor jacks 1.JPG
ID:	92359   Click image for larger version
Name:	Driver Side Axle Jack Retracted.JPG
ID:	92360   Click image for larger version
Name:	Passenger Side AxleJack 1.JPG
Old 10-20-2015, 08:34 PM   #39
leefl's Avatar
Looks like they were mounted to the suspension sub frame, rather than the main frame. That right ?
Old 10-20-2015, 08:47 PM   #40
That is correct.
fifth wheel, wheel
