Old 06-16-2016, 07:56 AM   #21
It sits higher, you'll turn wider, but man it tows like a dream. Super stable. You'll enjoy the experience.
If you're lucky, you got the 6 point self leveling system. My FAVORITE part of my new trailer.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
dwayneb236 is offline   Reply With Quote
Old 06-16-2016, 02:28 PM   #22
junebug39's Avatar
We did, love 💘
junebug39 is offline   Reply With Quote
Old 06-16-2016, 10:24 PM   #23
Left Coast
Consider awning poles.......
Old 06-20-2016, 09:17 PM   #24
wonxone's Avatar
We are trading our tt for a 5th wheel and plan on pulling it with a 2016 diesel f250 should that be sufficient
wonxone is offline   Reply With Quote
Old 06-22-2016, 04:31 PM   #25
Charles.maine's Avatar
What are the details on your new fifth wheel. Truck will probably work but there are some that are too big even for your truck.
2015 Chevrolet Silverado 2500HD 4x4 Z71 Duramax/Allison Combo Pull Rite, ISR Series Superglide 16K, LoadLifter 5000 Ultimate W/ WirelessOne
Current RV: 2016 Palomino Columbus 381FL Fifth Wheel
Lippert Flex Air Pin Box, LT235-85-16 GY G614
Nights Camped 2013 - 6 • 2014 - 7 • 2015 - 12 • 2016 - 29 • 2017 - 16 (17 more planned!!)
Charles.maine is offline   Reply With Quote
Old 06-30-2016, 04:58 AM   #26
shorthorn's Avatar
Very dependent on the model 5er. To honest, most 5th wheel's will exceed the payload of most all diesel 3/4 tons (which is why I just upgraded to a 1 ton). If you don't have the truck yet, you would be much better off getting a 1 ton... even a single wheel.
If you currently the truck look at the yellow sticker in your door jam. It will give you the available payload for that truck. For a 2015 Ford F250 Diesel, Crew Cab, Long Bed, 4x4, the availible payload is published to be 1,700 lbs. (wow thats really low) Take that #, subtract the weight of the hitch (200 lbs about) then subtract what your family weighs (payload weight assumes just 1 150lb driver) and the weight of any other equipment hauled in the truck... lets say you ended up with around 1400 lbs left.. Take that number and divide it by 0.25 (pin weights on 5ers range from 20 to 25% of total camper weight)... You come up with 5600lbs... In this example your F250 is over loaded with a 5er that weighs 5,700 lbs... and you won't find much, if anything, that light.
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
shorthorn is offline   Reply With Quote
fifth wheel, wheel
