Old 03-27-2011, 02:29 PM   #1
dezldog1's Avatar
Flipping Axels ??
Why would anyone "flip" the axles on a 5er ??
Pros, cons ??
Thnx guys !!
Jo
2010 Dodge Ram Laramie 2500HD 4x4 Diesel
Firestone Airbags
2006 33LCDTS Silverback
Curt 20k.Q5 Slider
dezldog1 is offline   Reply With Quote
Old 03-27-2011, 02:40 PM   #2
If you have a lifted vehicle, sometimes it's required to get the trailer up higher since it's much tougher to buy a lowered hitch like you can on a tongue pull. However, the proper way to do it isn't just to "flip" the axles, but rather weld new perches on the top of the axles.
caleb is offline   Reply With Quote
Old 03-27-2011, 03:36 PM   #3
dezldog1's Avatar
Hey Caleb,
Thnx for the reply.
We are hooked with a Curt 20k.Q5 slider But we are so low to the ground with back bumper of the 5er...I think we will be scraping bottom a lot if not very careful. Seems to be very little clearance at the rear bumper
This pretty much cancels out any boon docking thoughts. We need level ground at this point ....
Firestone Airbags
Curt 20k.Q5 Slider
Old 03-27-2011, 03:43 PM   #4
In that case, you could flip the axles (or have your dealer do it if you're not comfortable with welding on new perches) to gain the additional clearance. You may need to get a hitch that's raised if you're currently sitting level. If you're already higher than level at the hitch, then the flip would solve (or help solve) both issues.
Old 03-27-2011, 03:44 PM   #5
Also, there isn't really any cons to doing a proper flip if that's the setup you need to make your trailer ride correctly other than the higher center of gravity.
Old 03-27-2011, 04:13 PM   #6
dezldog1's Avatar
Thnx Caleb
Greatly appreciate your help with this. We are so new. Asking for all the advice we get in many areas before we "hit the road" once this snow melts. Sadly won't be anytime soon I'm afraid
Jo
Firestone Airbags
Curt 20k.Q5 Slider
Old 03-27-2011, 04:24 PM   #7
jimh's Avatar
the key word would be "properly." i'm assuming that u mean from over the spring to under. i did that with my last trailer because the trailer would hit the bed of the truck. the arch in the axel was bowed the wrong way after i finished. in other words, mine wasn't the proper way. didn't have any stability issues.
jimh is offline   Reply With Quote
