Old 07-29-2007, 11:03 AM   #11
milzat's Avatar
Originally Posted by RetiredArmyCWO View Post
started mine on the propane, then the electric. Works like a champ.
Good point.
This does work.
milzat is offline   Reply With Quote
Old 08-27-2007, 04:31 PM   #12
I had some similar problems with my RM model - it ruined several loads of food etc. I came to the conclusion that it was effected by being level. It would work fine - then if uneven for a little while it would stop cooling and then as the issues progressed it wouldn't cool at all. After a few days of being turned off it would start working again. But I didn't trust it anymore. I ordered a new one and we have been very careful to keep it level for extended periods of time.
'05 RAM 3500
'05 Sandpiper
'and as many toys and I can get in the F37!
Lovell's is offline   Reply With Quote
Old 08-29-2007, 12:37 PM   #13
2manytoyz's Avatar
It will get down to temp quicker on propane, but after 24 hours, it should be down to temp no matter how you started it. I start mine the day before on electric, and 12 hours is plenty to get mine up to speed.
Freezer at 2.5 degrees F:
Fridge at 44 degrees F:
I'm very careful to only operate mine while moving, or level when parked.
Robert & Dawn
2007 Rockwood 2502
2010 F-150 FX4
Equalizer Hitch -w- 1000# bars
Yamaha EF2400iS generator
http://www.2manytoyz.com/
2manytoyz is offline   Reply With Quote
Old 08-29-2007, 05:55 PM   #14
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
Ok...what's in the container marked PARADISE, and where did you get that cool thermometer???
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
