Old 06-25-2011, 05:47 PM   #11
I run with mine on, and don't worry about it while refueling. Almost always, the trailer is outside the classified area (API 500).
Mine is diesel too. However, diesel does NOT equal 'safe'. Many people think it is okay to run a diesel since it doesn't have spark plugs. But if there is ever a gasoline spill nearby, and your engine is running, it can pick up the gasoline fumes and overspeed. You can not turn off the engine in this case.
The engine can race uncontrollably until it - literally - throws engine parts. This has been the cause of several gasoline loading rack fires. A truck overfills, spilling gasoline and the truck waiting to pull in is too close and overspeeds.
Long story short - diesel does not equal safe
Keith & Liz
2010 SilverBack 33L
2009 F-250
kablair is offline   Reply With Quote
Old 06-25-2011, 09:31 PM   #12
2Susan's Avatar
We run with the fridge on.
However thinking about fridges liking to operate while level makes me ask the fridge gurus of the group - what about when you are in quite mountainous areas - always up or down, never seeming to be level? what problems could you foresee?
If we had problems in the mountains we've not noticed.
2Susan is offline   Reply With Quote
Old 06-25-2011, 09:47 PM   #13
We ALWAYS run with the fridge on.
Keith, you might want to check that out about gas fumes causing a diesel to race, sounds like an urban legend to me! (It's just fumes, not raw gas!)
Jack
2006 Flagstaff 831RLSS Travel Trailer
2007 Chevy 2500HD 'Classic' with the Duramax engine.
Converting a 1956 GMC PD4501 Scenicruiser, ex Greyhound into a motor home.
jackhartjr is offline   Reply With Quote
Old 06-25-2011, 09:58 PM   #14
Wanna Be Camper
SaskCampers's Avatar
we are on the road now and the fridge is and will stay running till we return home in July.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 06-25-2011, 09:59 PM   #15
Herk7769's Avatar
Jack
Thanks Jack. You beat me to it. I was going to ask for a source.
HAM CALLSIGN - KC3FFW
Old 06-25-2011, 11:23 PM   #16
Boyd's Avatar
Fueling
Remember, any appliance that produces a flame should/must be turned off when filling your on-board propane tank.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 06-26-2011, 06:01 AM   #17
onetonford's Avatar
Washed out a aircleaner for tractor with gas once didn't cause deisel to run out of control but did cause it to backfire and blow lid of air cleaner to go flying across shop. also had to wait for fumes to dissapate before it would crank as gas fumes would fire before top dead center and cause it to stop like hitting a brick wall.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 06-26-2011, 07:15 AM   #18
Fire Instructor's Avatar
The reason that an RV fridge has to be level to operate is to ensure that the refrigerant flows properly through the small tubes in the cooling system. If the fridge is kept unlevel for too long, the refrigerant settles in one "corner" of the system, and the fridge stops working properly. The ups and downs, bumps, slight sways, etc. of road travel keep the refrigerant well stirred-up, and settling isn't a problem. If anything, the fridge works MORE efficiently when traveling, then when sitting still.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 06-26-2011, 10:36 AM   #19
Diesel Engine Risks While Operating in Hazardous Environments | Well Servicing Magazine
Fuel Spill Prevention: San Antonio Refinary Explosion at Loading Rack operating under API RP1004
4261 - Intake Air Shutoff Valves
Crown Petroleum Loading Rack
<< I'll try to find the video of the truck as it literally oversped and blew apart; it is a 'standard' that is shown every few years at one of our monthly safety meetings>>
Yes - I'm in the hydrocarbon business.
Keith & Liz
2010 SilverBack 33L
2009 F-250
Old 06-26-2011, 11:13 AM   #20
Herk7769's Avatar
Here is an article on how the system works.
File Type: doc Fridge Operation and Trouble shooting.doc (414.0 KB, 7 views)
