08-04-2018, 12:40 PM
Front Travel Trailer A-Frame.
Has anyone else noticed if both frame rails on the front a-frame sit even on both sides? Mine is about 3 degrees or 1/4" lower on the driver (street side). There are no indications of broken welds or bends in the a-frame or where it attaches to the front crossmember section. Is this acceptable?
2013 Toyota Tundra DC Limited- 4x4, 5.7L, Factory Tow Package, Factory Deck Rail System, Factory Cargo Divider, Trac-Rac G2 Sliding Rack System, Bak Revolver X Rolling Tonneau Cover, Tekonsha P3 Trailer Brake Controller, Grand Aero Towing Mirrors, Andersen "No Sway" WDH.
2018 Sonoma 240 BHS: Fourth TT And Worst Quality So Far.
08-05-2018, 11:03 AM
I've tried to get answers by using the search function but no luck. Lippert "LCI" is going to look at it, however, some feedback here would be nice.
Bottom line: Does a front a-frame need to be perfectly straight on both sides for a travel trailer to handle properly? If not, is 1/4" tolerance acceptable?
08-05-2018, 11:14 AM
Of it wasn't off by at least a1/4" I would have been surprised.
08-05-2018, 11:17 AM
Is it made of a channel profile that they overlapped where they converge?
pictures?
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:18Nights
08-05-2018, 12:23 PM
It sounds like it's within tolerances then.
08-05-2018, 12:26 PM
pictures?
Let me see if I have some pictures, it's at Forest River now. I think the a-frame is an 8" boxed-in style.
08-05-2018, 12:35 PM
Here's a picture that shows part of the a-frame.
08-05-2018, 12:52 PM
I doubt that the jigs that Lippert builds the frames in are anymore accurate than that. Personally I would not have even thought to check it. I have owned 5 campers and about 10 other trailers over the years.
If it pulls fine and it should, I would not worry about 1/4".
I also would not be surprised if you checked it somewhere else you may have different results. The frames can twist a small amount depending on how you are setting.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
08-05-2018, 01:10 PM
Thank you for your feedback. I've had so many problems with this trailer and the factory warranty is about to expire. So, I just wanted to be sure it is normal and within spec. This forum is very valuable.
