05-18-2016, 10:32 AM
Furrion camera questions
Hi all
Do you have to be hocked to TV for camera to work? It doesn't work when I'm parked next to my 5er.
__________________________________________________ ____
2017 CC Silverback 29RE / UVW (dry wgh't.)=10,705 lb
Pin wgh't.=1,985 lb / GVWR=13,985 lb
2016 Ram Delmonico Red 2500 CC 4x4 6.7L Cummins
with rear air suspension 68RFE 6spd Auto 3:42 axle
Gvwr=10,000 lb GCWR=23,300 lb payload
05-18-2016, 10:44 AM
Hello. Depending on how it is connected you might need running lights on for it to work. Did you pair the system when it was installed?
B and B
05-18-2016, 10:47 AM
mine works either way but my camera is on with the trailer battery not the running lights.. probably not the way I would wire it but that's how they did it.
rob
05-18-2016, 10:48 AM
My Furrion Observation Camera is powered when the TT clearance/marker lights are turned on. For that to happen, the TT must be plugged-in to the TV electrical connection and the TV lights must be turned on.
Roger, Sherrill, and Harley (Great Dane)
2016 Flagstaff V-Lite 30WRLIKS [sold]
2012 F-150 XLT Screw 3.5L EB, 3.55
Air Lift AirCells, Blue Ox BX1500
05-18-2016, 10:51 AM
Hi b and b
Camera was installed at factory, it worked the day I picked it up, went to use it today and it wouldn't work. I was not hooked up just setting next to 5er.
05-18-2016, 10:53 AM
Try the MENU and PAIR. Read the book. Hold "pair" two seconds.
Mine quit after first 200 miles. Won't come back on period.
FROG AR-0019-242
05-18-2016, 10:57 AM
Originally Posted by Lilredram
Hi b and b
Again, most of these camera's get their power from the trailer running light circuitry. The running lights on the trailer have to be on, to power the camera.
Typically that is done by plugging your umbilical cord into the tow vehicle and turning on the park/running lights.
If yours is wired this way, sitting beside the trailer (with the umbilical cord not plugged in) would not allow the camera to have power to operate.
05-18-2016, 10:59 AM
Yes. Exactly how mine work(ed).
FROG AR-0019-242
05-18-2016, 04:12 PM
Yup
Plugged her in works fine. Thanks for all the help, this is a great forum.
RonG
