Old 11-03-2014, 02:14 PM   #1
FreddieMac's Avatar
Galley and gray water tank
I do not think one of the valves for my grey and galley tank is closing completely. I get a good amount of water spillage when I go to hook up the sewer hose. Is there an easy way to check and see which is giving me the problem. I am about to go camping a lot this month so may not get a chance to bring it to the dealer.
FreddieMac is offline   Reply With Quote
Old 11-03-2014, 02:55 PM   #2
Brother Les's Avatar
Have them both 'empty'. open both valves. turn on water to the galley. when water starts flowing, close valve. does water stop? If so good, if not find out why. Shut off water and drain. Next do the grey tank the same. start with valve open and start running water, when water comes out, shut valve..... this should tell you which valve is your problem.
Brother Les
Old 11-03-2014, 02:55 PM   #3
Cyber Phrenologist
Radio's Avatar
Get food coloring and dump it into one tank with a few gallons water. Plain water in the other tank. Whether the color is there or not will let you know.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 11-03-2014, 02:58 PM   #4
hrlyguy2's Avatar
Had both of my valves replaced already.
The stench was bad with the grey .
Galley wasnt.
Empty the galley and grey.
fill grey up first see if it leaking
If it doesn't its galley
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 11-03-2014, 02:58 PM   #5
FreddieMac's Avatar
Good thoughts, it was hard for me to tell this weekend which was the problem or if both were the problem. Just happy it was not an issue with the black tank valve! :-)
Old 11-07-2014, 11:31 AM   #6
FreddieMac's Avatar
Bringing the TT back to the dealer tomorrow to replace those valves.
Old 11-08-2014, 06:43 PM   #7
FreddieMac's Avatar
Valves did no need replacing, they adjusted them to make sure they work. Happy with the response of my dealer.
tank, water, water tank
