Old 09-06-2014, 10:38 PM   #1
FreddieMac's Avatar
Galley tank versus gray water tank
During my walk through today the guy was not able to explain entirely the difference between these two tanks. What is the difference?
FreddieMac is offline   Reply With Quote
Old 09-06-2014, 11:11 PM   #2
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Means 2 gray tanks, the galley tank for the kitchen sink and the other for the shower and bathroom sink.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 09-07-2014, 01:38 AM   #3
2007 WildCat 32QBBS
05CrewDually's Avatar
gal·ley
ˈgalē
noun
1. The kitchen in a ship, camper or aircraft.
05CrewDually is offline   Reply With Quote
Old 09-07-2014, 06:07 AM   #4
FreddieMac's Avatar
Ok thanks that was not quite his explanation, but makes that does work.
Old 09-07-2014, 07:06 AM   #5
Iwannacamp's Avatar
In my TT the "grey" tank is all grey water except the OK as I understand. It has it's own grey "galley" tank.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Iwannacamp is online now   Reply With Quote
Old 09-07-2014, 07:18 AM   #6
FreddieMac's Avatar
They guy said something about all sinks use the galley and the other is for the shower. But what is being said here makes more sense.
Old 09-07-2014, 07:24 AM   #7
Iwannacamp's Avatar
I wish that was always true...we don't use the shower. I use nearly all in washing dishes(sometimes I don't want to use the outdoor shower). I have thought about trying to re-plumb or tie the greys together. I don't even dent the OK grey tank.
2017 Puma 297RLSS
Old 09-07-2014, 07:50 AM   #8
rattleNsmoke's Avatar
He could be right depending on how your unit is plumbed. Typically it is just what the others have mentioned.
rattleNsmoke is offline   Reply With Quote
Old 09-10-2014, 05:42 PM   #9
Exiled Bohemians's Avatar
After five days, our bathroom gray water tank is almost full & our galley is pretty empty (quite a few dinners out this week).
Is there a good reason they are not connected? Is it possible (or advisable) to do such a thing?
Traveling 9/1/2014 - 11/1/2014
2015 Vibe 6504 • 2005 BMW X5
http://instagram.com/bohemians_in_exile
Exiled Bohemians is offline   Reply With Quote
Old 09-10-2014, 05:52 PM   #10
Dazed & Confused
M&K Hoffman's Avatar
If your setup looks like the attached photo it appears as though you could open both grey valves, leaving the cap on, and the two tanks should equalize. Some folks add a twist on valve so you don't get sprayed removing the cap when you need to dump.
M&K Hoffman is offline   Reply With Quote
tank, water, water tank
