Old 01-10-2015, 12:13 PM   #11
Happy Campers
Denny and Suni's Avatar
HAPCO makes a generator box for the Honda 3000. Diamond patterned aluminum box is $999.00 msrp.
"I went to the woods because I wished to live deliberately...and not, when I came to die, to discover that I had not lived." H. D. Thoreau
2012 Nissan Frontier 4X4 Crew Cab Longbed
2014 Flagstaff 21FBRS
Some Yorkies
Denny and Suni is offline   Reply With Quote
Old 01-10-2015, 01:08 PM   #12
Check out You Tube for Genny covers and boxes.
grayfox is online now   Reply With Quote
Old 01-10-2015, 02:06 PM   #13
Thanks for the responses. Sounds either too complicated ( tongue weight considerations or construction) and / or too expensive. I guess chaining to the hitch will have to do.
AbdRahim is offline   Reply With Quote
Old 01-10-2015, 10:02 PM   #14
Here's another option to secure your Hondas to your truck bed
LowPro LockDown generator security system for Honda EU2000i : LowPro LockDown generator security system for Honda EU2000i : Generator Accessories : Patio, Lawn & Garden
gthomp10 is offline   Reply With Quote
Old 01-10-2015, 10:12 PM   #15
Moderators' Assistant
bikendan's Avatar
Originally Posted by gthomp10 View Post
the OP has a SUV, not a truck. he wants to run it, so not something he can do with the obvious limitation of a SUV.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 01-11-2015, 02:25 PM   #16
Thanks for the thought though gthomp10.
Old 01-11-2015, 02:31 PM   #17
Crusadernoob's Avatar
Originally Posted by RPAspey View Post
Oh, the reason I use a cable is it is rubber coated thus not scratching anything and its very difficult to cut. Also its easy to manipulate thru the genny handles.
Unless it's about a 5/8" cable or larger all those cables and or chains can be cut very easily with cutters bought at the same home improvement stores you most likely got the cable at.
2006 2500HD Duramax CCSB 2WD
2014 Crusader 285RET
Nights camped in 2013 - not enough!
Nights camped in 2014 37
Nights camped in 2015 40
Nights camped in 2016 35
Crusadernoob is offline   Reply With Quote
Old 01-11-2015, 06:16 PM   #18
My TV is an SUV (Suburban), and I considered several solutions to allow me to run a genset at a truck stop w/o needing to move it around. I installed a receiver on the front of the truck and added a cargo tray, then built a box that allows me to open the sides while running or open the top and front to fuel up. Closes up going down the road to keep rain and bugs off. Then I have a semi-permanent line run under the truck to the rear so I only have to pull the camper's AC line to the rear of the truck, open the sides of the box and start up the genset. The genset and cargo tray is chained to the tow hooks on the front of the truck with a heavy chain.
I have a thread with pictures on another forum, IM me if you want a link.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 01-12-2015, 12:20 AM   #19
Retired on the weekends
The RB's Avatar
This summer I saw a little Honda strapped down on the roof of a camper.
Couple of weeks ago I saw a generator running inside a metal wire dog crate, which was chained to the rig it was powering. At first I thought it was nuts, but then realized it was a pretty ingenious plan.
Now that I think about it, a way to top off the security.... Electrify the crate with the the electric fence zapper.
2008 Sunseeker 3120 DS
The RB is offline   Reply With Quote
Old 01-12-2015, 01:36 AM   #20
GreenImp's Avatar
Send a message via MSN to GreenImp
Unfortunately nothing is theft proof, but I like this idea which I haven't seen mentioned in this thread yet (copied from another site)...
Use carriage bolts to secure a steel plate to the bottom of the generator frame with the nuts down. The plate should extend about two feet beyond the outside of the frame. Position the generator, then park your vehicle with the tire resting on the plate. Keep the muffler in mind when positioning the plate so that it won’t end up pointing at the vehicle. This method of theft prevention is often used by campers, but could certainly be used at home.
This could be combined with a chain/cable if you're really paranoid.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
generator, truck
