Old 09-17-2007, 06:00 PM   #1
HookMeUp's Avatar
Gray Tank Replacement
I would like to change out my gray tank and put a larger one in it's place. Are the drain lines that go into the top of the tank glued in or are they a slip fit into a grommet fitting?
HookMeUp is offline   Reply With Quote
Old 03-24-2008, 10:50 AM   #2
HookMeUp's Avatar
Bringing this back to the top to see if there is anyone that knows about this.
2010 Wildcat 30LOFT
2011 RAM 3500 CCLB Cummins
Old 03-24-2008, 12:23 PM   #3
I'm betting they are glued. Just a guess though.
aintgotnun is offline   Reply With Quote
Old 03-25-2008, 07:07 PM   #4
Buckymaster's Avatar
I had to replace my black water tank on a previous TT. Don't ask how it happened (Darn stump and YUCK!!).
Anyway. All ports entering the tank were glued. Tanks are generic and I had to drill out the holes where I wanted to put new fittings. These I had to glue in. I ordered the fittings, primer and glue with the tank. Although you can purchase the glues at the hardware store, I wanted to make sure I had the right stuff for the tank. It seemed to be thicker than reqular PVC/ABS glues.
The rest of the drain pipes were glued, I had to cut them off and add couplers to install the new tank.
NEW - - 2017 Shasta Phoenix 33ck
OLD - - 2007 Forest River Wildwood 312BHBS LA
OLDER -- 1997 Sunline Solaris T-2970 Advancer pkg
Still Running - - 2008 F350 CC Lariat 4x4 6.4 Diesel
Buckymaster is offline   Reply With Quote
Old 03-25-2008, 08:08 PM   #5
HookMeUp's Avatar
Thanks for the headsup. Doesn't sound like an easy swap but doable.
2010 Wildcat 30LOFT
