Old 04-25-2013, 07:54 AM   #1
charliek's Avatar
Heater Not Working
I have a new 38 PFS and all has been fine the last few months. This morning I woke up early cold. A cold front came through the night before. I had the furnace running all day with no issues.
This morning when I was awaken being cold I thought the propane gas had run out. So I checked the stove and the flame was low and yellow in color. I went outside to switch the regulator over to the other bottle. Came inside and checked the stove. All good there strong blue flame.
Went back over to the thermostat, which I did not turn off or change during the bottle switch. And no furnace running. I went through the cycles, off, fan, AC, furnace and it did not kick on. I raised the temperature and still nothing. I checked the circuit breaker box and all the fuses were on.
Any ideas?
charliek is offline   Reply With Quote
Old 04-25-2013, 08:09 AM   #2
Herk7769's Avatar
Turn off the thermostat AND remove the 15 amp fuse.
Wait a minute; plug the fuse back in and turn it back on.
When you run out of propane, the furnace has a safety system that prevents the system from running the "sparker" forever when there is no gas.
It will try to flush and light the burner just 3 times before it shuts off permanently. You need to remove power from the furnace to reset that safety system.
HAM CALLSIGN - KC3FFW
Old 04-25-2013, 08:16 AM   #3
charliek's Avatar
You da man! Thanks worked just like you said...
Old 04-25-2013, 08:31 AM   #4
Herk7769's Avatar
Glad I could help.
Old 04-25-2013, 09:03 AM   #5
wmtire's Avatar
I vote we give Lou a raise.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 04-25-2013, 09:59 AM   #6
Herk7769's Avatar
You can double my "no salary"
Old 04-25-2013, 10:25 AM   #7
wmtire's Avatar
That was the plan.
