Old 10-29-2011, 12:28 AM   #1
Vols's Avatar
Heater smell
Have an odor when the furnace is on is this normal? I don't remember smelling it b4.
Vols is offline   Reply With Quote
Old 10-29-2011, 06:21 AM   #2
KyDan's Avatar
IF your trailer is fairly new and it's the first time you've used the furnace in a while,
it's normal to smell like hot metal or something similar.
Mine smells slightly the first time it comes on nearly every trip.
More the 1st time of the season.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 10-29-2011, 08:00 AM   #3
I have the same answer than KYDAN. Small rust particles forms and dust on a long unused period. It will go away.
capucine is offline   Reply With Quote
Old 10-29-2011, 08:13 AM   #4
Vols's Avatar
Thank you both!
2nd question- how come the unit on roof will come on with furnace (floor vents)
The smell came only when floor vents were blowing. But then I adjusted temp from 66 to 70 (dh & ds were "freezing")
And fan on roof top came on as well
Old 10-29-2011, 08:28 AM   #5
grhodes50's Avatar
Set the fan to "AUTO" on your thermostat. If it's set on "HI" or "LO" the AC fan will run continuously whether using the AC or furnace.
Gary & Trish
2018 Nights Camped - 5
Old 10-29-2011, 09:53 AM   #6
Lottery Non-Winner
Ovair's Avatar
Originally Posted by Vols View Post
Thank you both!
Previous campers I have owned did not do that. However, the one I have now DOES do that. I figured it was just a method to help distribute the warmer air by circulation. As stated by grhodes50, do set the fan to auto otherwise it will just run and run and run as long as the heater is "on". In the auto position, the roof fan will only kick on when the heater actually fires.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 10-29-2011, 10:27 AM   #7
grhodes50's Avatar
Ovair, I don't believe AC Vols fan will run when set on AUTO while using the furnance. Mine doesn't.
Vols has a PT tt so I believe he has the same Dometic Digital Thermostat that I have.
Here's some operating instructions for the Dometic Digital Thermostat that I have posted before.
Use the On/Off Mode button to select FAN. Then use the +/- button to select either Hi, Lo or Auto. When using the AC and the fan is in the Hi or Lo setting it will run continuously while the compressor will cycle on and off. In the Auto mode the fan will cycle on and off as well.
If the fan is set on Hi or Lo while using the furnace, the AC fan will run continuously, so be sure to set the fan on Auto when using the furnace. When set on Auto the AC fan will not run, only the furnace blower which will cycle on and off. You can, however, leave the AC fan running while using the furnace to help with condensation problems.
Use the On/Off Mode button to select COOL. Use the +/- button to select the thermostat temperature setting. (same procedures for the furnace)
When using the AC with the fan in the Auto mode the fan will run on high when the room temperature is 5 or higher than the thermostat setting. When the room temperature drops to within 4 or less than the thermostat setting, the fan will stop for a few seconds the start again in the Lo mode.
Gary & Trish
