Old 01-24-2011, 08:52 PM   #1
Help on Dewinterizing sequence for my 5er
OK I have a new 2011 Blue Ridge and will be heading to Yuma on Friday, and as the Dealer Winterized the unit with the pink stuff when I was not there, I now need to Dewinterize it. Here is what I have. One lever marked RV with a normal position and a winterizing position. Curently its in the winterizing position. Below it I have a lever marked Hot Water Heater with a normal position and a by-pass position. Its currently in the by-pass position. Can someone who's done a similar procedure, give me the sequence to dewinterize it. Thanks
bailer6334 is offline   Reply With Quote
Old 01-24-2011, 10:12 PM   #2
Send a message via Skype™ to scubieman
Yes hook up city water run all water facets un till pink is done. Then the two levers switch them the other directions. You will be good to go. The pink is non toxic but try to flush with good clean water.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 01-25-2011, 08:20 AM   #3
Traveler II's Avatar
Yes, put the levers in there normal positions. You want to make sure that you have water in your hot water tank before you turn it on. Sometimes I need to open the pressure release valve on the hot water tank to let some of the air out. I also will sanitize my water tank.
Enjoy Yuma and your new rig.
Jim and Jane
2008 Cardinal 30TS
Trail Air Pin Box, Center Point Suspension
Reese 18K hitch - Garmin 1690 GPS
2008 Chevy 2500HD 4x4 Duramax/Allison, Long Box, Smartair
Nights camped in 2011: 120
Traveler II is offline   Reply With Quote
5er, 5th wheel
