Old 08-28-2010, 04:43 PM   #21
Herk7769's Avatar
When dry camping I spray the end of the hose attached to the potable water spigot. I never did before until I saw a woman letting her dog lift its leg against the pipe. The end was laying in the grass and you don't have to be a rocket scientist to draw the correct assumption.
As to the splitter, just MAKE SURE you have a one way check valve pointed the correct direction on it. When I use my turbo-flush the check valve burps water at the fitting (like its supposed to to relieve the pressure) when I shut off the water supply. Without the check valve in the feed line that water back flow WILL go into your coach's fresh water lines.
HAM CALLSIGN - KC3FFW
Old 08-28-2010, 04:45 PM   #22
Herk7769's Avatar
Originally Posted by revrnd View Post
Contrary to popular belief, I'm not a "man of the cloth". It's a nickname I got back in '80 when I was between jobs (don't ask).
The WallyMarts up here sell Thetford's Campa Chem single ply TP.
Jeez ya got me there!
You got the name; now take the blame!
Old 08-28-2010, 06:06 PM   #23
About the Coleman brand T.P. WHY? You can safely use any "septic tank safe" toilet paper in your system. Angel Soft, 2 ply, available at Wal Mart works just fine. 24 regular rolls 2 ply- 5.00. Try the water in a clear glass test. Take a small piece of your paper you want to use, put it in the glass, and stir it around a little with your finger (it's NOT a toilet). It should almost immediately start to dissolve in the water- Septic Safe. Randy
Old 08-28-2010, 06:29 PM   #24
CLASS "A" Senior Member
cfsoistman's Avatar
We've been using Scott brand for Septic Systems since 2006 when we were given a couple rolls at the Hershey RV Show. They were handouts along with coupons. We just look for it on sale and pick up a pack or two, we use it at the house as well.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 08-28-2010, 06:34 PM   #25
Mr. Black's Avatar
What toilet paper brand out there ISN'T septic tank safe anymore?
Are there any?
Steve
1999 Ford Superduty F250 PSD CC SB 6spd 4x4.
B&W goosneck/companion hitch, Airlift 5000 airbags.
2006 Sierra F28 Rear Kitchen 5th Wheel, 31' = 10k pounds.
Nights camped in 09-14, 2010-23
Mr. Black is offline   Reply With Quote
5th wheel
