Old 03-28-2010, 07:12 AM   #1
Traveler II's Avatar
How Level Is Level
I know you want your rig to be as level as you can have it. BUT, we are about 3” high from front to back. I’m unable to adjust the hitch or the Trail-Air. The Trail-Air will hit the rails I have for our cover. I’ve remove the slide flange already on the Trail-Air and it’s helps, but I’m unable to lower it or the hitch anymore.
My question is how bad is 3” to high in the front?
Jim and Jane
2008 Cardinal 30TS
Trail Air Pin Box, Center Point Suspension
Reese 18K hitch - Garmin 1690 GPS
2008 Chevy 2500HD 4x4 Duramax/Allison, Long Box, Smartair
Nights camped in 2011: 120
Traveler II is offline   Reply With Quote
Old 03-28-2010, 07:47 AM   #2
milzat's Avatar
3" out of level, front to back, on a 30' trailer isn't enough to worry about.
milzat is offline   Reply With Quote
Old 03-28-2010, 10:29 AM   #3
Ditto. I wouldn't worry about 3". When ya start hitting 5" then I would start looking at other solutions. Bigger trailer tires, flipping the axles.....
aintgotnun is offline   Reply With Quote
Old 04-01-2010, 07:51 PM   #4
does not sound like a big deal.
commander ryker is offline   Reply With Quote
Old 04-02-2010, 09:35 AM   #5
tmmar's Avatar
Don't have a trailer but I have a bullet level on the floor freezer. I get paranoid when any part of the bubble is out of the circle and will do everything to make sure it is all inside the circle.
Just my being anal I guess.
Tom and Margaret
2014 Berkshire 390bh-60
Old 04-02-2010, 05:54 PM   #6
flyrotor's Avatar
I think he's referring to being out of level when towing
flyrotor is offline   Reply With Quote
Old 04-03-2010, 08:12 AM   #7
Yes, it's when I'm hooked up to the truck. When we are parked I do level up.
Jim and Jane
2008 Cardinal 30TS
Old 04-03-2010, 09:00 AM   #8
tmmar's Avatar
Oops-- sorry for the mix up!!
Tom and Margaret
Old 04-05-2010, 10:07 AM   #9
OldSoldiers
OldSoldier's Avatar
On a 30 foot trailer, 3 inches "nose high" doesn't seam like a lot. I had a 25 foot 5er that was a lot higher when pulled by my diesel and eventually had to flip the axles. My new 8285WS rides absolutely flat on the road. I love it.
I wouldn't worry at this point. The general consensus here is not to worry.
Good Luck,
OldSoldier
OldSoldier is offline   Reply With Quote
Old 04-05-2010, 08:01 PM   #10
Knower of Some Things
Good Luck,
OldSoldier
Add my voice to the "no big deal" side, as long as it feels OK towing.
PumaPro is offline   Reply With Quote
5th wheel
