07-03-2016, 07:02 PM
How to fully drain and clean the black tank
Hello everyone my question is how do you fully empty the black tank after going camping.
The camper was level at the camping site ball valves are open draining into the sewer line I flushed everything down several times using the gray tank last flush the toilet bowl several times before we left to clean the system out but when we got home I have pulled the black lever and still had about 10 gallons come out by accident how is that possible if everything was connected at the site and flushed down several times any help would be greatly appreciated
07-03-2016, 07:07 PM
Despite what you might think, the drain on any of the tanks installed in an RV is not always at the very lowest part of the tank. In addition the tanks are flexible and sometimes supports will distort the tank in a way to create several low points. What you are seeing is not uncommon.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-06-2016, 07:44 AM
There will always be "stuff" in the black/gray tanks. Just do your best to flush it every so often(I do this when on full hookups), but then don't worry about it. Many people get fixated on this, and have to have it "clean". My routine for the last 15 years, is to always re-prime the black tank after dumping. In other words, once dumped, close the black drain valve, dump the tank deodorizer in, along with 3 toilet bowls full of water, now you are ready to roll for the next trip. Never leave the tank dry, and it will give you good service for many years. Also, in case you are not aware, when on full hookup, its ok to leave your gray water tank valves open, but always leave your black closed until time to dump. Otherwise what will happen is the liquids will drain out, leaving the paper/solids, and eventually will fill the tank to the point where it will never drain, and becomes like concrete. That's a repair bill you don't want to have to pay!
Dave
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
07-06-2016, 07:48 AM
I always try to leave 5-10gals in the black tank after dumping so going down the road it sloshes around
Sent from my SM-N920V using Tapatalk
07-06-2016, 08:04 AM
Dave
Personal preference, of course, but on the few occasions when we camp with full hookups I leave all of the valves closed until the tanks are full. What gets washed down the sink into the grey water tank can smell just as bad as black water, so it's best to drain with as much liquid as possible to flush the solids out.
For the most part we drain at home with a Flojet.
After draining I flush the tanks. When flushing I rinse (black) or backfill through the Flojet (galley and grey) for 30 seconds before dumping again, repeating until the water is (relatively) clear.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
07-06-2016, 08:09 AM
Who Dares, Wins
I use a flush king after dumping to back fill the tank a bit. Even after a good drain I still get a bit extra out after I let everything settle for a while.
2015 Chevy HD D-Max
2022 Impression 315MB
07-11-2016, 07:37 PM
I honestly don't care and don't worry about it.
I dump. I flush. I refill with a couple of gallons of water and drop a tablet. Done.
Keep liquids in there and you won't have problems.
07-11-2016, 07:39 PM
I used the flush king this weekend for the first time.
I noticed that as well. Back fill, dump. Poop. Backfill dump, poop.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
07-11-2016, 08:24 PM
Who Dares, Wins
I've been happy with its usage and cleaning abilities... Just do not leave the tank alone if you close it up to backfill... If it fills and you are not there... Well it makes a nice brown geyser out the roof stack!
2015 Chevy HD D-Max
07-11-2016, 08:38 PM
Canadian Contingent
I dump, use my black tank rinse and clear plastic elbow to view and then once clear water comes, pull the grey water. I run the taps in the sinks and then dump the grey again. Shut the gate valves. Add some "Happy Camper" run the water in the toilet and sinks for a minute and Alls good!
Les and Bonnie with 4 Leggers Bella and Shelby
2011 Cedar Creek Touring Edition 36RE 3 slide Full Body Paint pushing our 2015 Ram 3500 Laramie 4x4 CCSB SRW - Anderson Ultimate Hitch
07-11-2016, 08:41 PM
...it makes a nice brown geyser out the roof stack!
Speaking from experience?
'16 Cherokee Grey Wolf 26DBH
'13 Silverado 2500 HD - 6.0 Vortec / 3.73
Equilizer WDH
Goodyear Endurance Tires
07-11-2016, 08:47 PM
Who Dares, Wins
Oh yeah.. Old Poopful blew out the roof in Orlando... Never made that mistake again..
Sent from my SM-G930V using Tapatalk
2015 Chevy HD D-Max
07-11-2016, 09:59 PM
Ugghhh!
Equilizer WDH
07-12-2016, 07:24 AM
Ay caramba! DEFINITELY the kind of mistake you don't make twice.
07-12-2016, 07:46 AM
Dave
X2 same thing, leave ready for next trip. We seldom use black flush as the Dump Station do not have hose fittings. 90% we camp with only electric. On top of this water is not plentiful and we should not waste it cleaning a black tank.
B and B
07-12-2016, 03:37 PM
Who Dares, Wins
Originally Posted by Dr-G
Ugghhh!
Luckily I had flushed the tanks several times prior so it was actually pretty clean water... As clean as a black tank COULD be!
2015 Chevy HD D-Max
07-20-2016, 02:41 PM
I empty the black water tank and then close the valve and using the black tank flush about fill the tank again and empty and keep doing that until the water runs clear. I don't use my outdoor shower so that hose stays hooked up to the black water flush. I sometimes use hot water to wash out my black tank. Works for me
09-24-2016, 08:51 PM
How to clean the black tank
The biggest reason that holding tanks, on Forest River Camper, do not fully drain, is because they use "Flat-Bottom Tanks" instead of "Sloped-Bottom Tanks".
Our previous 5th wheel was a Keystone Copper Canyon, it had "Sloped-Bottom Tanks", and that camper would "almost" completely drain, when the camper was level.
Our current 5th wheel is a Forest River Cedar Creek Silverback, and has "Flat-Bottom Tanks". The bottom of the tanks "Bow Down" on the bottom, especially when filled with liquid.
When the camper is level, as when set-up at a campsite, the tank will never fully drain. There will be 2 - 3 gallons of liquid left in the tank. With the black tank, that means there will always be "poop" (smell) in the tank.
Our camper has the Lippert 6-point Level System. When we get ready to leave a campsite, the last thing I do is use the hydraulic system to raise the front landing gear, to 1.2 deg high in front, then raise the right side to 1.2 deg high on the right side.
I then do my normal back flushing. I use a Flush King & flush each tank until they run clear water.
There will be 2 - 3 gallons of liquid drain from each tank after the the camper has been tilted.
I just wish Forest River would use the "Sloped-Bottom Tanks" so they would fully drain when level.
09-24-2016, 11:58 PM
"Happy Camper" is the best on the market, IMHO. We never leave home without it.
2014 Rockwood Roo 23IKSS
2012 Dodge Ram 1500 Hemi 4X4
Me, Hubby and Luna the Lab
09-25-2016, 06:05 AM
We also use Happy Camper... have for 3-4 years.
