Old 08-15-2010, 10:36 AM   #1
Iggy's Avatar
Hughes Autoformer
I originally purchased my first Hughes Autoformer model 2130 with the lights on the side back in 1993. Being an electrician by trade I understood how low voltage would damage any electronics that needed 120 volt AC to run or convert to DC power.
You see if you load stays constant and your voltage decreases then amperage/current with increase in exact oposite proportion as to voltage. Ohms Law E=I x R, I = P/E
Load is our Power Converter. (Example only) It uses 120 volts at 5 amp. which is 600 watts.
This is a solid state device and converts 120 volts AC to DC volatge to power lights, AC thermostat controls, Refrigerator controls, etc.
If the shore power drops to 110 volts the amperage/current to run that device increases from 5 amp to 5.45 amps
If the shore power drops to 100 volts the amperage/current to run that device increases from 5 amp to 6 amps.
Also in conjunction with the lower voltage and higher amperage you have more heat and in many cases this also contibutes to solid state device failures.
With my new trailer I looking to buy the new Hughes RV430 model that has a 3 stage boost of 5%, 10% and 15%. It is a very expensive device but have you ever burnt up your refrigerator control board? Just the board replacement is about $250. Also consider that if you have your flat screen TV on or Microwave oven those also could fail over time from low voltage conditions.
I'm sure this will generate many questions and I'm here to help.
Oh If you have a ground fault or surge protection device that is not the same subject I'm speaking about.
So let the games begin by letting us know what you are using to correct low voltage in your rigs.
Old 08-15-2010, 11:57 AM   #2
Herk7769's Avatar
I talked at length with a neighbor at the KOA in Bellefonte PA this past week who had one. He LOVED it and would never hook up without it. Even though our power at the KOA was solid 120 the entire time, he still hooked it up. His logic was that you never know when a voltage fluctuation will result from events in the local area.
I am shopping for one now. The only issue I am struggling with is; do I buy a 50 amp or 30 amp one. My needs right now indicate a 30 amp job, but who know what I will be using "tomorrow."
HAM CALLSIGN - KC3FFW
Old 08-15-2010, 12:13 PM   #3
Iggy's Avatar
I would say if you have a 30 amp service now that's all you need.
Remember that the old model 30 amp is RV2130 has one boost of 10% and the new model with 3 stages of 5%, 10% and 15%
The older model is going for $379 and used $200 to $250
The newer RV430 is going for $439. I'm watching the price and hope it goes down before I need to buy.
Old 08-15-2010, 01:11 PM   #4
Herk7769's Avatar
thanks for the tip on the model number. I will fire up my PayPal and look in ernest.
Old 09-25-2010, 07:33 AM   #5
jimh's Avatar
it's been years sense i looked at the workings of an autotransformer. then it was only briefly.
i'm assuming u would need a 220 input with two 110 outputs for the 50 amp (assuming such an animal exist...i seem to remember an auto transformor was a single winding transformer with multipal taps....it has been a few years). or you would get two 50 amp and put one on each leg. (would only need one for 30 amp...could make it a 50 and add another later) the two would also work if u happened to be on the same phase for ur 50 amp...ie u plugged in one of those adapters to two sources to supply to both legs.
Now u've sparked my curiosity, when i get back to Lake Charles, i'm going to have to find my books and look it up.
jimh is offline   Reply With Quote
Old 09-28-2010, 02:31 PM   #6
We use a 10% boost, 30A model. We also religiously use a volt meter plugged into one of our wall outlets to monitor our voltage.
In the Texas heat, there many times when the AC usage at the house, park, resort drives down the voltage in the system and I worry about my hookup. I was surprised how often the Autotransforer was in boost mode.
Heavy. Expensive. But worth it.
Nights camped in 2010 = 21 nights
2008 Chevy CCab 5.3L 4WD Z71
2008 FR Surveyor 291
Champion Genset
Slpybear, Mrs Slpybear, Three Cubs
slpybeartx is offline   Reply With Quote
Old 09-28-2010, 03:39 PM   #7
Boyd's Avatar
Where has all the power gone?
Great thread, Iggy. Somewhere in my old, foggy brain I've touched on all this stuff, pre-RV'ing, but never thought to.....well, never thought. I just "assumed" (and you know where that leads) all shore power was up to snuff. From now on I'll be hooking up my volt-meter when we come in from the boonies and plug into the grid. If I find a great variance in supplied shore power, I'll pop for one of those 30 Amp modlels. Question: Is the Hughs Autoformer RV430 wired-in/plugged-in before or after the main supply?
Thanks again for the "heads-up."
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 09-28-2010, 04:13 PM   #8
Herk7769's Avatar
The Hughes RV2130 is a single stage auto-transformer with 10% boost.
HUGHES AUTOFORMER RV2130: eBay Motors (item 330431255037 end time Oct-04-10 09:41:06 PDT)
The Franks auto-transformer is a two stage auto-transformer with an 8% and 16% boost.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
They also make a 50 amp model.
The Hughes RV430 (the new one) is a three stage auto-transformer with a 5%, 10% and 15%
Hughes Autoformers ::
The new Hughes 50 AMP unit is an RV450
I have been watching them on Ebay waiting to hit the lottery.
They go between shore power and the camper. They can be permanently mounted inside with a little work. Just mount so the "boost on" lights are visible.
Old 09-28-2010, 04:20 PM   #9
Hatchet58's Avatar
okey, learned something New today, Now I have to tell the Wife it would be in our Best Interest to pick one up
Hatchet
Chevy 2500HD Diesel
07 SandPiper F305
Days camped 2011 "3" so far,
Hatchet58 is offline   Reply With Quote
Old 10-01-2010, 08:16 AM   #10
jimh's Avatar
ok, lets see how i can ask if i can run an input (50 amp service) that has 220 volts between the two hots and 110 from each ground or 0 volts between the 2 hots but 110 from each to ground, will one autotransformer work (i'm trying to see in my mind how they would connect that internally) or will i need two?
Sometimes i plugg in to a 50 amp service. other times i adapt from one 30 to the double 50. then there times that i plugg into two circuits and supply the 50 amp socket that i plug my 50 amp cable into. (one plug goes to one of the 50 amp hots and the other goes to the other 50 amp hot. phase between the hots on this set up can either be 0 or 180. i asked one of the manufactures this question and still hearing the tumble weed outside.
5th wheel
