Old 11-08-2018, 08:27 PM   #1
csc
Hydraulic jack vs. Stabilizer jacks
When changing my Salem Cruise lite tires should I gat an hydraulic jack or use my stabilizer jacks to gey tires off ground . Would my jack from my Ford F150 XLT be sufficient? Thanks.
csc is offline   Reply With Quote
Old 11-09-2018, 12:46 AM   #2
bikendan's Avatar
NEVER use stabilizer jacks for raising the tires!
They are not designed for that purpose.
Equalizer WDH
Old 11-09-2018, 09:54 AM   #3
Head Rambler
As Dan said, don't use the stabilizers to lift the RV.
The jack for your truck may be fine for lifting the RV, but you need to make sure that it will fit under the RV when the tire is flat and that it will lift one side of the RV high enough to change the tire.
I'd go out and actually change a tire with it if that's what you plan to use.
Gotta go campin!
Old 11-09-2018, 10:04 AM   #4
The most Important part is #1 SAFETY and # 2 is Location where to Jack! Your Ford jack might NOT be the proper jack to use Safely! Try a Ramp type Jack,they work very well for Most,Not all dual axle trailers! Jacking in improper locations can cause Very $$$$ issues! Youroo!! One thing I will Guarantee, when you NEED your Jack in a situation along the Road,there will be NO firm,level spot for the Base!
Old 11-09-2018, 10:12 AM   #5
Denver To Yuma In 90 Days
Don't jack the trailer by the axle, either...could result in a bent axle!
Buy or borrow a decent floor jack and lift the trailer by the frame, then use another floor jack or a bottle jack to lift the tires off of the ground using a suspension joint behind the tire.
It is also a good idea to have the trailer attached to the tow vehicle or double make sure that the tires are chocked to keep the trailer from moving.
JohnD10 is offline   Reply With Quote
Old 11-09-2018, 11:14 AM   #6
csc
Thanks so much youroo ive checked these out and this is a FANTASTIC idea.
Old 11-09-2018, 11:30 AM   #7
csc
Thank you so much!!!!!!. I've checked these out on Amazon along with video and what a great way to EASILY change your tire.
Old 11-09-2018, 11:49 AM   #8
bedubya's Avatar
Ramps won't always work with dual axles. The spring hanger between the axles on my Salem CruiseLite articulates. So when one tire goes up on the ramp, the other stays on the ground. I have to jack the frame.
'17 Toyota Tacoma 4x4 TRD Sport
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
Days Camped: 2017-39, 2018-61, 2019-64
bedubya is online now   Reply With Quote
Old 11-09-2018, 03:31 PM   #9
You can jack the trailer axle if you jack where the trailer springs are attached. If your trailer does not bend the axle at the spring attachment point, then why would a jack. The downward force of the trailer sitting on the axle is much greater than the force required to compress the one spring. I use a 4 ton bottle jack to raise one end of my axle. I have a dual axle trailer.
Walholler is offline   Reply With Quote
Old 11-09-2018, 03:54 PM   #10
bikendan's Avatar
Many ultralight trailers have torsion axles, not leaf springs.
Equalizer WDH
Old 11-09-2018, 04:32 PM   #11
bedubya's Avatar
That makes sense to me.
Old 11-09-2018, 04:33 PM   #12
bedubya's Avatar
That may be, but mine has leaf springs.
Old 11-10-2018, 06:51 AM   #13
Perfect
I do the same.
pdqparalegal1 is offline   Reply With Quote
hydraulic, jacks
