Old 06-14-2015, 03:40 PM   #11
offroad's Avatar
Originally Posted by burch42 View Post
offroad;
thanks for the pictures what did you use for caps on the bottom of your poles?
It's just the soft handle that came on the painting poles. I just shortened it for looks.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 06-14-2015, 05:42 PM   #12
I used the exact same painter poles as offroad and stuck these on as feet. Shaving off the rubber hand grips from the poles was the most difficult part of the whole project. The built in hole step mech makes setup a 2 second afterthought.
rana is offline   Reply With Quote
Old 06-15-2015, 05:09 AM   #13
Loneeagle's Avatar
Poles
I may be off base on this but from the picture you posted, the cabelas camping poles might work. As a portable and not permanent option. With a strap down could work. I have used the poles for years with tarps and they are very strong, light weight and height adjustable.
Link below:
Cabela's Adjustable-Height Tent Poles
Cabela's Adjustable-Height Tent Poles : Cabela's
Ford F-150 4X4
2015 Flagstaff Micro Lite FRBS
2013 Flagstaff "A" Frame - Traded Up.
Camping Days 2013 - 24
Camping Days 2014 - 21
Projected Camping Days 2015 - 30
Loneeagle is offline   Reply With Quote
Old 06-15-2015, 10:49 AM   #14
burch42's Avatar
Link below:
those look like they may work too, I am inn Ontario so I found that Canadian tire has them and they are already painted black per the picture so that will help out.
burch42 is offline   Reply With Quote
Old 06-15-2015, 02:06 PM   #15
OC,
Do you have any more pole mounting kits for sale?
Jim
Jim & Pat
2014 Coachmen Freedom Express 297RLDS LE
2014 RAM 1500 HEMI Quad cab
jd48 is offline   Reply With Quote
Old 06-15-2015, 03:33 PM   #16
Originally Posted by jd48 View Post
OC,
Jim
PM sent.
Old 06-16-2015, 04:16 PM   #17
burch42's Avatar
i painted up the brackets black to blend in and went with tent poles that are fully adjustable. I have decided to keep my poles stored under my bed instead of leaving them attached just going to use the D ring supplied by OCClick image for larger version
Name:	ImageUploadedByForest River Forums1434489361.842512.jpg
ID:	80186Click image for larger version
Name:	ImageUploadedByForest River Forums1434489383.119500.jpg
awning
