Old 06-13-2015, 09:11 PM   #1
burch42's Avatar
ideas for awning poles
finished installing OC's kit (just the top bracket) and im looking for ideas on poles, can anyone help with pics on what they did?Click image for larger version
Name:	ImageUploadedByForest River Forums1434247845.210613.jpg
ID:	79842Click image for larger version
Name:	ImageUploadedByForest River Forums1434247862.037992.jpg
burch42 is offline   Reply With Quote
Old 06-13-2015, 09:17 PM   #2
1" and 1-1/4" elec. pvc. You need to heat about 3" of the 1" with a hair dryer or heat gun and squeeze it down to 1" in a vice to fit in the top bracket.
Old 06-13-2015, 09:46 PM   #3
Have YOU come to right place!!
#1 - Now that you have dry fitted your brackets, bring em on back down, prime and paint, then reinstall.
#2. Follow the diagrams and specs for the do it yourself poles found in the awning thread. OR...
#3. Do the quick and dirty like some of us and use expandable painter poles.
They are light weight.. but not as light as OC's.. cost a fortune more, but they are pretty much ready to paint and install out of the box with just a few modifications such as adding additional height adjustments holes. You'll probably want to add some kind of "foot" (tons of other examples that others use in the thread) to your poles.. and you will want to make sure you have a decent spiral type tie down kit (which is the whole intention of your O.C. brackets).
#4. If you plan to travel with your OC poles in the installed/stored position, you'll need to pick up some D clips. At least for the upper and storage brackets. I use an additional set for the "feet" on mine.
If you DO go another route than the PVC's make sure you make drain holes at the bottom as needed to allow for rain water to exit your poles. There is nothing like retracting your O.C. poles and getting an up-spray of water from the filled lower leg.
Ask Epy. I don't know how many times he has retracted his and gotten a "spray wash", but we are all waiting on baited breath to see if he has learned his lesson yet.
Disclaimer: I don't even know for sure if Epy even has O.C. poles, but had to throw in a "rip". It's been far too long.
rana is offline   Reply With Quote
Old 06-13-2015, 09:52 PM   #4
Originally Posted by Yarome View Post
...#4. If you plan to travel with your OC poles in the installed/stored position, you'll need to pick up some D clips. At least for the upper and storage brackets. I use an additional set for the "feet" on mine...
Why do you need D clips when all you have to do is install the lower stow brackets, use them as template and drill a 9/32" dia hole all the way thru the pole and insert the 1/4" hitch pin?
BTW, the elec. pvc is the cheapest route, both poles and caps for less than $20.
Old 06-13-2015, 10:55 PM   #5
HA! Because English is not easy and now I did my research. It's not "my" D pin.. and not "your" hitch pin. Technically they are "wire lock pins". But they are the same animal. Post hole pin with a retainer.
With regard to the pole costs.. with all due respect, I thought that was the point I was making with regard to the PVC poles. To re-iterate.. pre-made extendable painter poles are exponentially more expensive than a PVC pole setup. To quote myself, "cost a fortune more" (painter poles) than OC's PVC diagrams.
For the "on the go" though they are functional out of the box, fully customizable and fully compatible....
...Wait just a second!! Oh crap! You were just screwing with me for payback for the comment I made last week?!?!, right!? DANG. I walked right into that one...
NO Folgers for you!!!
Old 06-14-2015, 12:07 PM   #6
Mr. Dan's Avatar
Looks like this:
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 06-14-2015, 12:15 PM   #7
Originally Posted by Mr. Dan View Post
Looks like this:
The "D" ring(hitch pin) should go thru both the inner and outer poles.
Name:	Stow bracket.jpg
ID:	79900   Click image for larger version
Name:	Stow Bracket complete.jpg
Old 06-14-2015, 12:56 PM   #8
Mr. Dan's Avatar
Mine do. I just have shorter poles - but plenty long enough.
Sent (I think)
Old 06-14-2015, 01:40 PM   #9
offroad's Avatar
I posted about my painter pole install here.
http://www.forestriverforums.com/for...d.php?p=853572
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 06-14-2015, 03:31 PM   #10
burch42's Avatar
offroad;
thanks for the pictures what did you use for caps on the bottom of your poles?
thanks to everyone for their responses.
awning
