Old 02-09-2015, 07:48 AM   #121
Originally Posted by MtnGuy View Post
Same here.
I will look for a big CCC in my next trailer, also. I beleive the more you stay under the GVWR, the better it is for the suspension, and especially the tires.
This is the reason I have stayed away from the "lightweight" travel trailers and always gone with a traditional aluminum sided rig. Seems like most aluminum sided rigs have from 2000-3000+ CCC while the typical fiberglass rig has 800-1500. Load range D versus Load Range C tires is very common, too.
Old 02-09-2015, 08:15 AM   #122
I see these behemoth fifth wheels being towed down the highways at nearly 70 mph and wonder how difficult they will be to maneuver in critical traffic situations. I pull a 6500 lb trailer with a half ton F-150 and I know that even this combination can be stressful in certain situations.
Rockwoodjoe is offline   Reply With Quote
Old 02-09-2015, 04:45 PM   #123
Total Bliss's Avatar
It's very stressful pulling trailers. Where I worked, I had to pull a 28ft cargo trailer for our jobs. Sometimes across a few states at a time. Mostly construction items and material. We did quite a few schools and hospitals. Wind and weather was our main concern. Couldn't stop, had to get to the job.
2016 Silverado Dually
2016 Cedar Creek Champagne 38el
Total Bliss is offline   Reply With Quote
Old 02-09-2015, 10:19 PM   #124
fx2
Mine is a fiberglass side with load range D tires.
2014 Surveyor SC321BHTS
2016 Nissan Titan XD SL4x4 Cummins
fx2 is offline   Reply With Quote
Old 02-10-2015, 07:47 AM   #125
That would make yours "atypical". Are they 15" load range D? Maybe the ones I looked at had load range D but they were 14" with a 2040 capacity instead of a 2540 capacity???
Old 02-10-2015, 08:25 AM   #126
fx2
Ours are 15"
A Lot of the fiberglass trailers we looked at had CCC of more than 2k lbs, though some were as low as 1500 lbs. Even 1500 - 2000 lbs is plenty for an average family.
Old 02-10-2015, 08:49 AM   #127
Witch Doctor's Avatar
The 15" are the 2540 capacity, I have the 15" on mine.
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-10-2015, 08:55 AM   #128
Ours are 15"
One of the main lines we looked at was the Rockood Ultralite and SUL. The highest CCC on any SUL TT is 1647- most are in the 1400s. That is a base model. Add some options and you are probably in the 1200s. We would be right at the max loaded. Most of them you actually have to deduct tongue weight to come in under axle and tire ratings. No way I'm rolling on China bombs that are MAXXED out. I looked at a KZ that was even worse. Don't remember the model number, but it was the rear entertainment TT and it was barely over 1K when optioned. So, not sure what brands you were looking at, but the main ones I was looking at didn't have enough CCC to suit me.
Old 02-10-2015, 08:56 AM   #129
That's what I said. 14" have LRD have 2040 cap.
Old 02-10-2015, 08:58 AM   #130
MtnGuy's Avatar
I have a fiberglass sided, lightweight trailer. The brochure listed the trailer at 4139 lbs, the certificate of origin at 4614 lbs., and running it across some scales before loading for camping I came up with 4760 lbs.....there was water in the water heater, and maybe a bit in the fresh water tank. With a GVWR of 7559 lbs, I have a actual CCC of 2799 lbs......not to shabby. And that is with a 28.5' trailer.
Of course, that might be non-typical for a lightweight trailer.
weight
