Old 08-04-2016, 12:10 PM   #1
mekkerlc's Avatar
Is it okay to put slides in AFTER hooking up?
I would like to speed up the time it takes us to pack-up and leave for our trips. One part that irks me is that I feel I shouldn't hook the 5'r up to the truck while the slides are out...and then when we are ready to go, put the slides in and pull away.
Essentially, when we get back from a trip, I park it on the driveway, which has slope to it. I level the unit front to back with the landing gear. We will put the slides out before our next trip to pack and clean, etc...
My hesitation is that when I put the 5'r onto the truck, the weight is shifted to the pin box, and the frame of the camper is tweaked slightly. Does this have a negative effect on the slides going in?
Sounds confusing
Luke & Carolyn
2012 Cedar Creek Silverback 35QB4
2013 Sierra 3500HD Duramax CC SRW SB 4x4
Andersen Ultimate Aluminum 2 Gooseneck Mount
mekkerlc is offline   Reply With Quote
Old 08-04-2016, 12:14 PM   #2
asquared's Avatar
I have run my slides in and out while hooked up. The key is do not plug into TV until unplugged from pedestal.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 08-04-2016, 12:35 PM   #3
mekkerlc's Avatar
Yes I have run my slides in and out while hooked up as well but my question is it okay 2 run slides in after hooking up when the slides were out while being on front legs of camper?
Luke & Carolyn
Old 08-04-2016, 12:38 PM   #4
Ford Idaho's Avatar
I prefer to run the slides in and out once the lite has been leveled and the stab jacks on deployed.
When moving out the last thing is the Slide goes in, jacks up, truck hooked legs up, pads and blocks put away.
Make sure all doors are closed and locked, power cord is put away, light check break away cable hooked.
I never rush when moving out because I will likely miss something.
Ford Idaho is online now   Reply With Quote
Old 08-04-2016, 12:41 PM   #5
Every manufacturer's recommendations I've ever dealt with says to operate the slides once the unit is properly leveled & stabilized.
Can you do it otherwise... yes.
Should you... ????
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 08-05-2016, 02:43 PM   #6
Tfort's Avatar
They say not to buy most dealers run them out on the lot no mater how level it is or isn't and move hem around with a fork lift with them out.
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 08-05-2016, 02:44 PM   #7
NMWildcat's Avatar
Should you... ????
I think the preferred method is to unhook, stabilize, and then run the slides out and the reverse when leaving. And this is what I try to do. But there are also times when hooked up that I will run the slides (or 1 of them) in and out while hooked up. And yes I've hooked up while the slides were out as I was getting impatient waiting on the DW, and then brought in the slides. But I don't prefer to do that. I, like yourself, worry about the stress point changes so I try not to do it often.
Scott and Liz - Southern NM
Old 08-05-2016, 02:46 PM   #8
Tfort's Avatar
My last site I didn't dare hook up before I slid it in. Was way to close. Click image for larger version
Name:	ImageUploadedByForest River Forums1470422803.643849.jpg
Old 08-05-2016, 02:58 PM   #9
Left Coast
Originally Posted by Tfort View Post
My last site I didn't dare hook up before I slid it in. Was way to close. Attachment 116386
For that very reason I installed a RF remote controller.....I like to see what it's gonna run into!
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
Old 08-05-2016, 03:21 PM   #10
I use Hitchin Rods for aligning up to hook up the tt, ...... on one of them I have marked two points that I always want to know,....... the height from the ground up that I need to crank my trailer tongue to do the hookup, and the 19" that my slide comes out,.... I can easily grab it as a measuring stick to see if anything is going to be in the way of my slide coming out 19",..... I like to KISS(keep it simple stupid)
Magnetic Hitchin' Rods - Qworks HR01D - Trailer Towing Accessories - Camping World
https://qwks.com/Hitchin-Rods-p-2.html
fella10 is offline   Reply With Quote
slide, slide out
