Old 05-26-2016, 05:19 PM   #1
Is it really necessary?
This is directed to those of you that use a tripod up front to stabilize your 5th wheel. Mine has a chain that runs throuh the legs, I get that it would supposedly stop the legs from spreading apart but I'm having a problem believing that once some weight from the pin is applied how is that tripod actually going to collapse? Especially if you are on solid ground. To me it just looks like additional weight to carry that item around. Any thoughts?
2017 Grand Design Reflection 367BHS 5th wheel.
2017 F350 crew cab 6.7 4X4 srw.
clicker1944 is offline   Reply With Quote
Old 05-27-2016, 11:29 AM   #2
Head Rambler
Even though it's putting some pressure on the pin to stabilize the unit, as you move around in the RV it moves a little and that can cause the legs to spread if there's not something to restrain them.
If you want confirmation just remove or leave the chain loose and see how much it will settle during a weekend outing.
Gotta go campin!
Old 05-27-2016, 12:42 PM   #3
2007 WildCat 32QBBS
05CrewDually's Avatar
If you don't like the chain, replace it with a nylon pull tight strap. Light weight and easy to use.
05CrewDually is offline   Reply With Quote
Old 05-27-2016, 12:51 PM   #4
Rugged Brown's Avatar
I had a fifth wheel tripod. I used it a couple of times. Didn't see any noticeable difference in stability and found a sucker the next week to sell it too.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 05-28-2016, 12:32 PM   #5
NMWildcat's Avatar
x2!!!
Old 05-28-2016, 01:01 PM   #6
CDR USN Ret
Originally Posted by NMWildcat View Post
x2!!!
X3
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
DSQR is offline   Reply With Quote
Old 05-28-2016, 01:46 PM   #7
DaveSchwartz's Avatar
Tripod stands are not intended take much weight - they are only supposed to bear enough weight to take out the slack. That's why they are called stabilizers and not jacks.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 05-28-2016, 03:22 PM   #8
I love this Idea! Gonna adapt it right now!
OfficerMike is offline   Reply With Quote
Old 05-30-2016, 10:45 PM   #9
Had the same kind of stabilizer. You are absolutely correct. Just unnecessary and cumbersome weight to drag around. Did no noticeable good. Found a scrap steel pile and tossed it.
Jordyn is offline   Reply With Quote
