Old 09-20-2014, 07:22 AM   #1
Is my Truck too big?
I have a 2014 Ram 2500 with 20" tires. My question is whether the tires are too big for a 5er?
Mine is on the left.
Name:	ImageUploadedByForest River Forums1411215677.625161.jpg
Bobert is offline   Reply With Quote
Old 09-20-2014, 07:42 AM   #2
hrlyguy2's Avatar
All depends on what hitch you get.And if you can adjust the pin box.
I Had a Gmc 2500 with 8" lift and 35" tires on 17 rims and was good ..
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 09-20-2014, 07:45 AM   #3
RKR
RKR's Avatar
Hook it up , check bed rail clearance , make sure your tires have the proper load rating , and make sure your 5er isn't too un level. You don't want to carry too much weight on one axle.
Sent from my high tech gadget
RKR is offline   Reply With Quote
Old 09-20-2014, 07:51 AM   #4
MC9
20" tires aren't necessarily bigger in diameter.
MC9 is offline   Reply With Quote
Old 09-20-2014, 08:21 AM   #5
jonrjen's Avatar
20" tires are usually a lower side profile that will equate to a smaller diameter wheel with a taller sidewall.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 09-20-2014, 08:23 AM   #6
Thanks for the input.
Old 09-20-2014, 08:52 AM   #7
mikkeeh's Avatar
Whats the weight rating on those tires? That could be an issue.
mikkeeh is offline   Reply With Quote
Old 09-20-2014, 10:05 AM   #8
mcnabbwr's Avatar
You should be okay unless you have something other than stock. My F350 came stock with 20 inch tires. The fifth wheel sits perfectly level and there is plenty of clearance between the bed rails.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 09-20-2014, 10:51 AM   #9
RKR
RKR's Avatar
I think he means 20" rims. My former 2500 HD came with 20's. It was fine.
Old 09-20-2014, 11:02 AM   #10
I also have an F350 with 20 inchers. 5r sits just about perfectly level with 9 inches of bed rail clearance.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
truck
