Old 08-29-2015, 06:16 PM   #41
Originally Posted by gljurczyk View Post
On a Rockwood #8289 there is a 2" duct that blows into the basement. But remember the R/A has no ducts so when the furnace is on it also pulling warm air down there from your living space...
Going to call FR on Monday. Have three or four questions for them to answer. I have called them in the past and found that the tech's try to be helpful.
What year is the 8289? I have an 08 8280SS which only has one slide for the living area. They discontinued it in 09, still offered the 8280 but with two slides, the 8280WS has a living area and a bedroom slide.
Just went to FR web site and looked at their winter package. There was no mention of duct work so no help to me.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 08-29-2015, 07:05 PM   #42
That Stat will work with your new unit, you just do not hook-up the blue and one of the fan wires. Honeywell will tell you no because your trying to hook it up to a 12v system and not 24v. The batteries takecare of that. same as any other battery stat like hunter or other honeywells...
I will try it again but was so disgusted I almost threw it out, LOL! I get that way at times. I had to go look in the trailer to be sure I didn't.
replacement therostat
I had started a thread about doing it. Was so aggravated I never went back to it.
Was given a wiring diagram but it didn't work. It was for converting a Coleman Mach Analog Thermostat to the digital stat. Didn't work because on my old stat blue is not ground, it is hi-fan and needs to be hooked up. My old stat is a Duo-therm made by Dometic. It uses 7 wires. It looks like this one.
Dometic 3106995.032 Analog Thermostat Cool Furnace Trailer Camper RV
Jim
George Bernard Shaw
Old 08-29-2015, 07:18 PM   #43
Witch Doctor's Avatar
Recent Discussions
Dometic Brisk Air II Heat Strip Add
Jim
Blue should be a ground, and you should have a green and gray for high and low fan speeds. Try hooking it up to
R- red wire
y-yellow
g- to green or gray
w- white to white wire
tape the rest of the ends and leave them
then see if the honeywell will work. Do you have a H/P? It shows h/p on the cover plate. If you have a HP it will not work. Get back to me so I can research this for you...check this thread
Recent Discussions
Dometic Brisk Air II Heat Strip Add on the forum
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-29-2015, 08:09 PM   #44
Crockett's Avatar
The problem with these that I have found is that it WILL increase the air flow:
Pro's
1) more air flow
Con's
1) 110 Volt
2) temp problem being the FPM of air will fell like a draft only
he was looking to circulate air to basement through the furnace when it was not on Glen. only when he was only operating an electric space heater.
dave
Crockett is offline   Reply With Quote
Old 08-29-2015, 08:38 PM   #45
R- red wire
y-yellow
g- to green or gray
Recent Discussions
A H/P? On the new Honeywell? Nope, no such marking.
Jim
George Bernard Shaw
Old 08-29-2015, 08:54 PM   #46
WolfWhistle's Avatar
From an old post...
Obviously this won't work for everyone, but since I don't care to heat the toy bay and its only me, it works great. This came from a member Norstar99, to give credit where due. The reason this was necessary, is that the furnace in these units are only 19K BTU. This mod reverses the flow of air incoming from the registers and supply is out this added 10 x 10 louvered grill. Also, my main heat source isn't this very inefficient LPG furnace.
"Completed the furnace mod. Removed and left off the furnace covers (both the one made of wood and the interior access cover); removed 2 ducts (moved them to the sides to act as return air vents); taped up the duct holes (2 layers) taped the furnace to the cabinet to direct the hot outward (filled the gap); added 10" x 10" louvered grill cover (painted black). This was Northstar1960 idea. Since we don't care about heating the garage, the heater will work much better and might actually put out 19K BTU. I think a 12" x 12" grill would have worked a little better. Got grill and aluminum tape from HD."
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 08-30-2015, 03:02 AM   #47
Jim
No I was talking about the link you provided it showed h/p on it. If you do not have a h/p it should work with an a/c and furnace only....The honeywell you showed is a heat/cool only. The battery in the stat will take place of your supply voltage. Do you have 1) AC and 1) furnace? If you say your blue wire is the high speed fan wire hook that up in place of the green or gray that I mentioned before. Blue has always been ground on other units you only need 4 wires.
Old 08-30-2015, 03:16 AM   #48
dave
Sorry Dave I kinda was answering 2 different questions. To circulate air in the basement just add a switch to the blower motor and turn it on. I know OC has done this for years. He heats with a eden and just turns the blower on for the furnace.... OC WHERE ARE YOU?
Old 08-30-2015, 07:43 AM   #49
Phat Phrog Stunt Crew
elind's Avatar
In my Wildcat I have two insulated hoses going to my underbelly in my basement. This would work for me if I put in a booster inline blower. Then put in a 40 degree thermostat in the underbelly to turn it on when the temp drops.
2014 Wildcat 327ck
elind is online now   Reply With Quote
Old 08-30-2015, 09:28 AM   #50
Ok, maybe I will go play later today. I only have one ac unit and one furnace, only one zone. I knew the stat is only a heat / cool stat with one fan speed but that is all I need in the trailer. I have an expensive good stat in the house and haven't used the program feature sense I retired.
I was given the thermostat diagram sheet from a "new" old style Dometic analog stat by a rv mechanic. It shows the field wiring as:
+7.5 as red or red/white
fur as white
hp/hs as violet or orange
cool as yellow
fan as orange or tan
gnd as black or green
Hi-fan as blue
The Dometic stat has three switches, heat / cool, fan auto or on and a high low for fan speed. I could add the fan speed switch to the new Honeywell but never used the low speed so why bother?
Inside of the Honeywell stat there is a switch to set for a gas/oil furnace or an electric or heat pump. I have no heat pump so left it set on gas/oil, so that should not be a problem.
Jim
George Bernard Shaw
furnace
