Old 03-13-2017, 07:59 AM   #1
Mammoth's Avatar
Jumping from pop-up to trailer items
Hello all. We are making the move this year from a pop up camper to a hard walled one. The popup was basic with just heat and a fridge. The new camper has a bath and kitchen. I have all the supplies from the other camper so I'm pretty well stocked. But I'm curious if there's things I may need to buy that I would need on the new that I didn't on the popup. Like a sewer hose and things. Any recommendations would be helpful along with any brand preference.
Thanks for the help
Mammoth is offline   Reply With Quote
Old 03-13-2017, 08:29 AM   #2
Besides a good quality sewer hose I would add a water pressure regulator, water hose, 30AMP extension cord, wheel chocks, and with all the on board electronics in your new purchase consider a Progressive Industries EMS/surge protector. Extra fuses are always a good thing to have too.
Old 03-13-2017, 08:52 AM   #3
A"TPMS" would be a good investment also. I like the TST 507. Good luck with your new RV.
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
hdmtnrider is offline   Reply With Quote
Old 03-13-2017, 09:05 AM   #4
phillips's Avatar
Thanks for the help
As far as sewer hose and connections go I would recommend the Camco Rhinoflex. Click image for larger version
ID:	131733Click image for larger version
current TV-2016 F-150 3.5 Ecoboost Max Tow
current TT-2016 Apex 300BHS
Reese Dual Cam WDH
phillips is offline   Reply With Quote
Old 03-13-2017, 09:16 AM   #5
Mammoth's Avatar
Thanks for the info. I'll take a look at those.
Old 03-13-2017, 09:18 AM   #6
Mammoth's Avatar
For the surge protector is there one I diff look at? There are many on their website.
Old 03-13-2017, 10:24 AM   #7
First you need to decide if you want a portable or hard wire unit. Then ask yourself if you may upgrade to a 50 amp RV later. (You can use a 50 amp protector with your 30 amp RV with the use of a 50-30 amp adapter. As you can see on their website an EMS/Surge Protector protects your RV the best. i.e. EMS-HW50C or 30C for hard wire or the EMS/PT50X or 30X for portable.
Old 03-13-2017, 01:11 PM   #8
Stormrider151's Avatar
Make sure you have what you need to change a flat tire. This is easily forgotten when buying a larger trailer. All jacks are not created equal and can be very frustrating if they just wont do the job. If your new rig has tandem axels (2) I would suggest a "trailer aid". That's what I use along with an electric impact wrench. Good luck and happy camping.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 03-13-2017, 01:13 PM   #9
Mammoth's Avatar
Thanks. It's a single axle. And I always assumed the jack from the truck would work.
Old 03-13-2017, 02:07 PM   #10
It might. Then again it may not. I found this out the hard way. Try it before you hit the road. It will give you a lot of piece of mind to know you can handle a flat if it happens.
Old 03-13-2017, 02:07 PM   #11
Mammoth's Avatar
Thanks. That's good advice
Old 03-13-2017, 03:26 PM   #12
Campahedu's Avatar
Send a message via Skype™ to Campahedu
Getting lots of good advice... wish I had a list when I traded up 3 years ago. I was lucky because Stormrider is absolutely correct about a jack. The time to find out you should have one IS NOT WHEN YOU NEED ONE. I like the TST 507 for tire pressure monitoring (as was mentioned). It is a little pricey but works flawlessly. Happy Camping
"How I feel when there is no coffee? DEPRESSO"
Chris & Deb
2013 F150 3.5 EB,Wildwood X-Lite 262BH
Campahedu.com
Campahedu is offline   Reply With Quote
Old 03-13-2017, 04:14 PM   #13
X2
foretm is offline   Reply With Quote
Old 03-13-2017, 05:17 PM   #14
MartiB's Avatar
It's handy to have a 50 amp adapter - especially if you go to FROGtober Fest. Which reminds me - I need to buy one so I don't have to borrow the one from the campground again.
Marti
2015 Salem CruiseLite 241QBXL
2021 Nights Camped: 29 (so far)
2020 Nights Camped: 18
2019 Nights Camped: 18
MartiB is offline   Reply With Quote
Old 03-13-2017, 05:22 PM   #15
Trailer-aid will still work with a single axle also. (If you still have room to still get under the trailer that is)
Old 03-13-2017, 05:41 PM   #16
Mammoth's Avatar
I'm buying a wolf pup 16bhs and it has 30 amp. So would I need a 50a adapter? Do some CG only have 50a service?
Old 03-13-2017, 05:42 PM   #17
Mammoth's Avatar
Originally Posted by foretm View Post
X2
Thanks. Added to my Amazon list. What length do you think is good? 15 ft? And will it be able to still store in the rear bumper?
Old 03-13-2017, 05:44 PM   #18
Mammoth's Avatar
Looked them up. Wow pricy. That might have to wait a little but I'll put it on my list.
Old 03-14-2017, 03:50 AM   #19
Always Learning
It's so easy to get overwhelmed (and broke!) with everything you need, should have, and want. I tried to identify the bare minimum for a first trip and then share a handful of "should haves" here:
http://learntorv.com/newbie-first-trip-essentials/
Old 03-14-2017, 03:51 AM   #20
Always Learning
See if this helps:
http://learntorv.com/what-surge-prot...est-for-my-rv/
trailer
