Old 03-11-2014, 02:33 PM   #1
tumbleweed1's Avatar
Keyless entry
We have keyless entry and was told to hold our hand over the numbers to light up them and then enter #'s but it half the time works and gets frustrating at times. I learned yesterday if you just touch the first # and hold it a couple of seconds then enter the rest of the numbers it works every time! It was getting irritating to keep trying and not unlocking the door. Hope this helps someone. 😃
2014 Siearra 355RE
Dodge 35000
tumbleweed1 is offline   Reply With Quote
Old 03-11-2014, 04:39 PM   #2
Chewie's Avatar
Is it a Bauer? If so what edition. Some have been replaced due to not "waking up." I've noticed with mine, the warmer it is outside the better it performs.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 03-11-2014, 07:50 PM   #3
Not sure what kind but my RV is a Sierra 355RE. The lock works great every time now that I learned the trick. Mine wakes up sometimes and sometimes don't.
Old 03-11-2014, 08:58 PM   #4
Mine too. Thanks I'll give this a try.
Marks is offline   Reply With Quote
Old 03-12-2014, 07:48 AM   #5
I don't even wait to get the numbers to light up. I just press the first number of my code for 2 seconds then when I go to press the rest of the numbers are lighted up and so far it works every time.
2014 Siearra 355RE
Dodge 35000
Old 03-12-2014, 08:39 AM   #6
SKnight's Avatar
If you lock yours with the key, will the keypad unlock it? Mine won't which is why I ask.
I figured out the same trick you did, I'm just not sure how comfortable I am with it yet.
Old 03-12-2014, 08:52 AM   #7
JoeMazz's Avatar
Originally Posted by tumbleweed1 View Post
We have keyless entry and was told to hold our hand over the numbers to light up them and then enter #'s but it half the time works and gets frustrating at times. I learned yesterday if you just touch the first # and hold it a couple of seconds then enter the rest of the numbers it works every time! It was getting irritating to keep trying and not unlocking the door. Hope this helps someone. ��
I just went through this. Bauer sent me 3 locks before I got one that works "most" of the time. I find that instead of tapping the pad to get it to wake up, I hold my finger on the pad until it lights up. It seems to respond more to heat than touch. It's still temperamental as hell though...
2015 Jayco Precept 35UP
JoeMazz is offline   Reply With Quote
Old 03-12-2014, 09:49 AM   #8
If I lock the top lock with the key, no it won't unlock it with the keypad but if I use the key to lock the bottom lock it will unlock it with the keypad.
2014 Siearra 355RE
Dodge 35000
Old 03-12-2014, 02:37 PM   #9
I just got my camper with the lock. I read your supposed to run you finger on either side of the keypad and it will light up the keypads. So far it's worked every time for me.
2014 XLR Thunderbot 415AMP
RugRat is offline   Reply With Quote
Old 03-12-2014, 03:30 PM   #10
SKnight's Avatar
Hmm, mine won't. The bolt doesn't extend as far with the pad either. Man, that's irritating.
Old 03-12-2014, 04:36 PM   #11
:thumbdown:
2014 Siearra 355RE
Dodge 35000
Old 03-12-2014, 04:42 PM   #12
I just tried it and your right it does work! The guy that showed us told us to put your hand over the numbers and then key in the numbers. It works less than half the time like that.
2014 Siearra 355RE
Dodge 35000
Old 03-12-2014, 05:04 PM   #13
I actually found that on their website since I didn't get the book at delivery.
Old 07-27-2014, 08:49 PM   #14
Just got my new Sierra with the Bauer Keyless entry, locks excellent unlocks excellent with the new code., until I closed the door for real time test, the door will lock with superior ease, but will not unlock, I have to use my key which turns super super easy so I know its not binding. Works great with the door open testing it, only lock when door closed. Also put in new batteries??????
mrwoodmin is offline   Reply With Quote
Old 07-28-2014, 01:35 AM   #15
Who Dares, Wins
doc73's Avatar
They have excellent customer service. Email them and they, I am sure, will take care of you.
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 09-14-2015, 09:28 AM   #16
Mine does the exact same thing!! It will lock no problem but will not unlock. What did you end up finding out?
kogden is offline   Reply With Quote
