Old 01-29-2016, 10:02 AM   #11
I got on the roof this morning and could not see anything that looked like it might be leaking. I also took the cover off the AC and could not see where it might be leaking. I have call FR customer support and waiting on a call back.
kdowdy is offline   Reply With Quote
Old 01-29-2016, 06:51 PM   #12
Tfort's Avatar
I don't have the same setup but I have had trouble with my return sucking the water back in the drain. When it's really humid and a lot of condensation forms in AC unit or when heavy rains hit it pulls it back in. If remove the filter the leak stops. Dealer is still trying to fix it.
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 01-30-2016, 10:41 AM   #13
Blog: RVroadtripper.com
hbillsmith's Avatar
I had the same issue on my 2016 Wildcat 295rsx. In a very heavy rain storm, a small amount (collected about 6-8 ounces over 8 hours) dripped thru the return air vent that's located in the ceiling (if you're facing the bedroom headboard, it's above you to the right).
I was going to take it in for warranty and called the dealer's service dept to get an appointment. The person that took my call was actually a service tech. She said they see that particular drip many times on front mounted A/C's. She said in each case they remove the A/C cover and tighten down each of those 4 bolts. It was simple to do, I did it and no leaks since.
I don't know if they loosened during travel or if the factory didn't tork down enough, but I can tell you my leaks appear to be gone. If they come back, I'm going to go up and tighten again. By the way, I'm a novice and was fearful that removing that A/C cover would be complicated. It wasn't. The hood screws are obvious and easy to remove.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 01-30-2016, 04:01 PM   #14
Thanks for the info, I will try that and see what happens. We are supposed to have rain again mid week.
leak, vent
